Zalman Reserator XT
29 Sep 2004
Newcastle Upon Tyne
Just finished the install and booted up... little bit worried tho as TAT reports my CPU temps as 45oC idle (they were 40oC idle before on air) and the front of the reserator shows 25oC and 25oC
The CPU is a core 2 duo e6600 @ 3.3ghz
Turn to manual control and turn the fan+pump to maximum. If it doesn't reduce the temps then reseat the cpu block as the S775 retention bracket can cause the block to wobble. :(
Its on manual sorry should have said that - still damn quiet :eek::D
Hmmm maybe I added to little paste or could be that I ran out of AS5 and used the stuff that came with it
