Zalman T1 Mini Tower Case - pre-order now!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
We have a great new value orientated case available for our customers. This case offers full GPU support and if you don't use an optical drive you can fit a dual radiator in the top :)
Zalman T1 Mini Tower Case - Black ** OcUK Exclusive ** @ £24.98 inc VAT
When you combine functionality with value you get the Zalman T1 case offering a great chassis design; made with limited space in mind due to the unique HDD's mounting methods this case should fit any small desk.
- Dimensions: 169 x 425 x 340mm ( W x H x D)
- Material: Plastic / Steel
- Motherboards: MicroATX / MiniITX
- VGA Size: Up to 270mm
- 4 Expansion Slots
- Drive Bays: 5.25" x 1 / 3.5" x 2 / 2.5" x 1
- Front Cooling: 1 x 120mm Fan (optional)
- Top Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 92mm Fan (included)
- Side Cooling: 2 x 92mm Fans (optional)
- I/O Ports: 2 x USB2.0 / 2 x Audio
Only £24.98 inc VAT.
ORDER NOW
hmm lookign to get some parts for a 2nd pc ....... does this case on limitations on the size of cards it can take ? basically there anything it will struggle with ?
This has potential to be a great budget wc case, looks to take a nice thick 240 up top and a 120 in the back.
Actually looks quite nice for it being zalman and £25.
had a quint squint on graphics section ... product desscription doesnt mention length of cards .....may adding that would help potential buyers ?
