Afternoon All,
I'm hoping I have posted this in the correct sub-forum.
I have a Zalman Z11 Plus case, it has 2x 80mm fans on the sides to provide extra air flow however the fan on the right hand side now makes a really loud noise when I turn my PC on, if I smack the case where the fan is it stops, it also stops once I am on the desktop screen as well.
I'm thinking of replacing the fan as I think it may be a bearing issue, I checked the fan and nothing is stopping it from moving.
The two fans currently connect up using Molex connectors and do not connect into the MB. Is it worth replacing these? If so, would this be a suitable replacement? http://www.overclockers.co.uk/showproduct.php?prodid=FG-021-AE
Thanks
iFrag
Thanks
iFrag
