Zalman Z9 Plus Midi Tower Case
25 Aug 2013
i've heard a lot of good things about this case...however, is it as good as they say? and it says it fits 290mm graphic cards so im assuming there will be loads of room for a 270mm one.
Also would it be worth going for the Z11?
I have my 2nd family PC in one of these, it was good for the money assuming it's about £50. It has four free fans, 2 controllable by the fan controller and a temp monitor. Has good air flow too and a couple of filters to stop some dust, still gets dusty though!
Personally I don't like the looks but can't fault it too much. There's other cases that may be better in other ways for the same price though like the Bitfenix Shinobi, Corsair 200R, etc.
I have had one as my main rig for 2 years now, and love it. My graphics card is 270mm long and fits with no problems. For the money you won't get a better case with the number of stock fans.
I've been using one for almost two years now. I have put a msi tw3 7970 in mine and it just about squeezed in but had to move some hdd cables behind my 24pin cable. temps aren't a problem but I'm not happy with how cramped it looks in my rig now so will change my case in the new year
