Zalman Z9 Plus U3 Temp Display Help
9 Jan 2016
Newcastle-U-Lyme, UK
Hi, I have just built my new pc and all is well :)
Only thing I cant work out is that the temp sensor display which come on the case has a molex to supply power to it, it has a red and black cable into it, im not sure if its classed as male or female (It is the type which has holes for prongs to go into) my problem is that my psu molex connectors to supply the power are the same connector type so how can I power it? :S
The power connector to the temp readout should have female connectors and the molex from the psu will fit inside.
They can be a bit tricky sometimes.
IMG]http://sgcdn.startech.com/005329/media/products/gallery_large/LP4SATAFM12.B.jpg[/IMG
basically its one of them on both the connectors I want to connect together
Please don't hotlink I have edited your post.
The PSU should have the female as per your image, the Zalman case should have a male connector.
You may need to speak to Zalman.
oh ok sorry I wasn't sure how to share the image
that's what I though but they are both female, I have ordered a male to male molex cable now, finally managed to find one so hopefully thatll do the trick
No probs, if you do want to add a image to a post in the future sign up with Imgur or Photoshack which are hosting websites and are free.
Can you take a photo of your connector and upload or even email me, I am just intrigued :p
