Zalman Z9 space?
3 Feb 2010
Behind you
Ive just ordered a Zalman Z9 that arrives tomorrow, i also ordered a Gelid GX7 CPU cooler
I have a slight concern that either the cooler is too big or my Corsair Builder Series CX 430W cables wont reach..
Please could you put me out of my misery? :(
Cheers
I've used a CX430 and all of the cables fitted in a large ASUS case without any hitches.
According to the Overclockers UK product description the case is
20.7cm wide, 46.4cm long and 50.4cm on the side.
I would imagine that it would all fit in there, with a bit of room to spare - could be wrong though!
I have a Thermaltake Frio in my Z9 case, so assume the Gelid unit you ordered should fit fine. No idea how long the cables are on your power supply, but the ones from my Coolermaster Silent Pro M700 reached fairly easily to both the 8pin CPU power connector, and the 24 pin motherboard connector.
