Zalman ZM-GWB2 gpu block
13 Dec 2003
UK
Hi there, im looking to use a pair of these with a 7/16" swiftech kit
does anyone know if this will fit the tubing fine (with clamps if need be)
on the main site it does say it can be used with other w/c systems
but i cant in the world find the barb size, i know thew zalman tubing
is very flexible and expands quiet a bit to go over the gpu blocks.
either a pair of these for £28 or a set of maze 4's for £50+.
Im not really into performance, just looking to watercool the cards.
On the cheap may i add ;)
any help appreciated :)
