Zalman ZM-MFC1 Mod?
15 Jun 2009
Hello i was thinking of buying the Zalman ZM-MFC1 fan controller
ppic-MAXI-Zalman-ZM-MFC1-plus-Fancontroller-zalman-fan-controller-6-channel-aluminium-zmmfc1ps.jpg
i was wondering if anyone has one of these and could tell me if i could take of the alluminum front and replace it with one of the front bay covers from my black Tj07? so it will match perfectly?
Or does anyone know of a good fan controller that will go with the black Tj07?
Does it not match good enough as it is?
Agreed, buy the black one. However if you are wanting an exact match (the black on is shiny anodised brushed effect, the TJ-07 is matt) then yes the cover is easily removed.
Im looking at doing somthing similar with mine, Theres a slight gap at the top and I get a glow shining through from all the LED's. Looks easy enough to remove to me.
You just drilling a few holes in the normal bay cover?
