Zalman ZM-MFC1 Plus power issues
19 Feb 2009
So I am nearly at the end of my build (my first one) and cannot work out how to connect the Zalman fan controller to my PSU (or indeed MB if it should fit there). The instructions on the box are useless to say the least. Can someone show me what cable I need and where to plug it in? If you could link to the cable on the OC website that would be even better. I have a Be Quiet modular PSU but none of the supplied leads look like they would fit and there is nothing in the fan controller package that is a power lead.
Please, someone help me - I am so close to finishing the build!
Thanks for the reply. And yes, that is what I thought looking at that diagram (same as comes with the box). But the 4 pin connector is too big - it looks like the one on the Zalman is a much smaller variety. Anyone using one, or have fitted one, knows what it uses?
