- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Zalman ZM-MFC3 Multi Fan Controller
The Zalman ZM-MFC3 fan speed controller uses a real time power load display unit to keep you fully updated on your computer's current statistics. The Zalman ZM-MFC3 uses a FSTN display for wide viewing angles allowing the display to always be clear and even. The ZM-MFC3 has the capacity for temperature monitoring of up to 4 components of your choice. The display shows: Fan RPM monitoring & control (3 x voltage, 1 x PWM), timer display and a built-in protection circuit & alarm.
- Real-time display of PC uptime and overall power usage
- Ultra-clear FSTN display with wide viewing angle
- Four sensors for temperature monitoring and display
- Monitoring and control of 3 standard fans and 1 PWM fan
- Alarm system to notify non-operation of any of the fans
Only £42.99 inc VAT.
BUY NOW
BUY NOW
