ZALMAN ZM NB47J on DFI SLI-DR EXPERT?
Like this:
If you need more space you can always hack off fins.
Minstadave said:
It runs about 10 degrees cooler with a silent 92mm fan blowing towards it than the stock cooler.
Looks cool, but is that a sli-dr expert? Looks like another dfi board, I think the expert got more space between the pci-e ports :)
Ooops mines an Ultra-D, I missed the Expert bit.
Depending on the graphics card you may be able to squeeze it in with an unmodded zalman, or maybe with the top row or two cut off:
I'm looking through the glass now to imagine if it would fit :p . Not sure, but I think it would be enough to cut off a row of pins maybe. I'm ordering one tonight anyhow, it's so freakin' cheap :D
bye the looks of it it will fit just the little heat sink on the end of the gtx will be the problem. here a pic if it help any.
Well, I just fitted it and it works great! :D I didn't have to modify it at all. But remember that you should have some proper airflow going over it. I'm so lucky that my radiator fans are blowing over it, so it stays cool enough. ;)
*enjoying the silence*
