zalman zm-rsa woes
26 Jan 2005
Cheltenham, UK
I just bought one of zalman zm-rsa ,which splits my pcs 6 channel output into to 2 x 6 channel outputs, I was planning to plug my zalman headset in and have my pc speakers in so that I didn't have to switch the cables at the back.
However the central/subwoofer outputs are both sunk into the unit so I can only plug the headphones as the sunk in area won't fit my speaker jack in, the sunk in area only fits the zalman headphones.
Has anyone else encountered this problem and if so how did you get round it?
Thanks
Joel
