Zen 3 memory voltage question
31 Oct 2012
I just got a 5900X and pretty much everything else needed to build my next system bar a graphics card in a few orders over the last couple of months. I just put everything into part picker for reference more than anything else, and I spotted a compatibility warning for the memory kit I picked (Team Group 8Pack RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 3600MHz, 1.40-1.50v VDIMM) :
"Memory operating voltage of 1.5 V exceeds the AMD Zen 3 CPU recommended maximum of 1350 mv+7% (1444.5 mv). This memory module may run at a reduced clock rate to meet the 1350 mv voltage recommendation, or may require running at a voltage greater than the AMD recommended maximum."
My question; should I swap kits to something with lower voltage or is the warning in part picker not warranted?
I just got a 5900X and pretty much everything else needed to build my next system bar a graphics card in a few orders over the last couple of months. I just put everything into part picker for reference more than anything else, and I spotted a compatibility warning for the memory kit I picked ( DDR4 PC4-28800C14 3600MHz, 1.40-1.50v VDIMM) :
Dont worry about it, you need those voltage if you wish to overclock to max of that ram or have super tight timings (cl14 3600 be 1.45v probably). Get a standard cl16 kit if you don't like those high voltages and just want to run at 1.35v@3600mhz
What board you got?
What board you got?
Thanks, that is what I was hoping, but as I havnt actually powered everything up yet I figured it would be good to ask here.
The motherboard is a ROG STRIX B550-A.
