ZENITH GAMING PC
2 Jan 2019
Can someone please help me out, I have around £1500-£1600 to spend on a new gaming desktop PC, Have used intel for all of my systems in the past but I do like the look of this offer Overclockers have on at the moment.
Can someone check the system spec that I have chosen below and give me some ideas of if these parts would work well together and the system would be good enough for AAA gaming.
Case.
Lian-Li Lancool One Digital Midi Tower - Black Window
Memory.
Gigabyte Aorus RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual/Quad Channel Kit
Graphics Card.
Sapphire Radeon RX VEGA 64 Nitro+ 8GB HBM2 PCI-Express Graphics Card
Primary Sold State Drive.
Intel 660P 512GB M.2-2280 PCI-e 3.0 x 4 NVMe QLC 3D NAND Solid State Drive (SSDPEKNW512G8X1)
WiFi.
Asus PCE-AC56 Dual-Band Wireless AC1300 PCI-E Adapter (90IG00K0-BM0000)
Power Supply.
600W 80Plus Bronze Rated PSU
Motherboard.
Gigabyte X470 DDR4 Motherboard
Cooler.
AMD Wraith Prism CPU Cooler
Storage Hard-drive.
Seagate 2TB 7200RPM Hard Drive
Any help on this would be appreciated.
Regards
@yamyam91
Push the Windforce 64. Better designed PCB/board. 12+1 VRM Vs 7+1 along with UK RMA and rep support on here along with OCUK support
I have been reading on the internet that the windforce 64 is a worse card than the Sapphire 64?
I know the sapphire card is power hungry and can get warm but does it out perform the windforce card?.
Do you think the 2 case fans that come with the build are sufficient for the card to remain cool
PCB of windforce 56/64
https://www.tomshardware.co.uk/gigabyte-radeon-rx-vega-56-gaming-oc-8g-review,review-34151-2.html
Sapphire
https://www.tomshardware.co.uk/sapphire-rx-vega-64-nitro,review-34125-2.html
same reviwer, 5c-9c difference as vega 64 will run a little warmer then 56.
both are 2.5 slot designs .
windforce is dual 100mm fans and Nirto+ is 2x 92 and 1x 80mm if i remember correctly
gigabyte has the better warranty and pcb, sapp is the better designed cooler
