Searching for GPU:s I found this:
"EROCORE POWER
AMD is introducing with the Southern Islands chipset their long idle power saving technology. Now the graphics card can turn off most of its functional units of the GPU, when they are unused, leaving only the PCI Express bus and other components active. This as a result, reduce the power consumption from 15W at idle to under 3W in long idle, a power level low enough that ZeroCore Power shuts off the fan as there is no heat generated further saving energy."
EDIT: Ok so it's called "ZeroCore power" and that's why I didn't find any info about it....
Which HDxxxx cards really have this thing??
do all Hd7870 have them but not all HD7850 for example? Or is it according to the manufacturer?
And does it turn off the fans on the GPU? And that makes the card essentially quiet?
I'm looking for a card that is more or less quiet when I'm doing normal office things - when gaming it's ok with a bit of noise.
This one okay?
http://powercolor.com/Global/products_features.asp?id=410
"EROCORE POWER
This one okay?
