Zeroing your hard drive
3 Jan 2009
I'm considering selling my macbook but before I do so I'd like to ensure that no sensitive information can be retrieved from my hard drive. I gather "zeroing" the drive is the best way to do this. From what I understand it's simply a case of: insert the Mac OS X DVD, hold down the "c" key then follow the on screen instructions. Is that right?
I'm using an aluminium unibody macbook, 2GHz C2D, 4GB DDR3 with a 250GB 5400RPM HDD with about 130GB free space. Any idea how long this might take to zero and whether it's something I could leave running over night?
Also, my computer came with Leopard installed, I've since bought Snow Leopard. Can I zero from either disc and will the OS automatically be reinstalled upon completion?
I think zeroing will take 7 times longer than a standard format. Worth doing if you're moving the MacBook on.
It should do that size disk overnight no problem.
