- 24 Apr 2006
- SE England
I plan to use FreeNAS and plan to purchase a 16 bay server case.
My issue is of expansion. It is too much of an outlay in terms of cost to purchase 16 drives in one go. So, I wish to expand the ZFS array over time.
I understand that you cannot add single drives to a ZFS pool, you would need to destroy the pool and then recreate the pool with the newly installed disks. This is very annoying and such a limitation. I understand that the file format was not really intended to be used in a home situation, but you'd of thought that it would have been adapted to include this feature by now.
I've read that it is possible to add new disks and expand the pool by adding the same amount of disks to the pool, by building a new RAID set, I believe? I'm having a really hard time tracking down information on exactly what to do and how to do it, which I find a bit crazy. Has anyone got any experience or can you point me to a guide? I need to find out whether this is possible and plan this properly before I commit money in to the hardware required.
Thanks for any help
Thanks for any help
