nope you can use them from the zip file. Although when yuo run it from a zip file it still extracts it to a temp folder each time. So may well be a time saver to extract it anyway if its going to be used a lot.
Its for coursework that has to be handed in today and I was making sure it was working from the .zip folder but as it was going to a temporary directory it wasn't working as it should.
When you extract to the folder though it works, I've just included a little text pad note in the folder saying this
