Zips become corrupt when uploaded... HELP !!!
20 Sep 2003
Scotland
Hi
I have an issue with zip files that is causing some problems, at work we use the zip compression format to compress a html template that contains a lot of wmv video clips. When i create the zip file and test it on my local pc everything extracts fine and plays back with no problems. But once it is uploaded and i try and access the file to download it i just get a load of garbble in my browser. Some of the zips are ok but i find its the larger files of 80mb to 100mb that cause the problems.
I am using WinRAR to compress them using the "Store" option for compression an FlashFXP to upload them.
Any ideas as to what it might be ?
TIA
It's set to auto detect
I actually thought of that just as i was typing this post so i will give it a try tomorrow.
