Zombie Ballistix.
15 Sep 2006
Liverpool
Well my Crucial Ballistix PC5300 died last week so I used my old AMD stuff. I couldn't boot at all with either of them in, i'd just get one long continuous beep then it would shut down.
Anyway, my OcUK RAM arrived and I installed the new mobo/cpu again. As I was about to turn it on again, I just though, why not try the dead RAM again, may aswell try. Installed one stick of the dead Crucial, and it booted fine. Turned the computer back off, installed the other one, booted fine too. So now I'm running 2x512mb OcUK PC6400 RAM and 2x512mb supposedly dead Ballistix RAM. Weird.
Is it normal for RAM to play dead like that? Maybe it wasn't even the RAM in the first place that died. :o
Also: I'm getting realy poor performance from this 2gb of RAM. On a fresh XP install, it takes like 8 seconds to just load up Firefox, and like 4 seconds to load up something when I choose it from the Start menu. :(
perhaps your cpu is throttling maybe.and i have some problems with ram playing up as well.
i have a 512mb stick that refuses to work with anything, but on its own its fine. still completely borked, as 512mb isnt enough these days
Someone else reported in a Ballistix thread that his RAM died, then he tried it again a while later (days maybe?) and it worked fine.
netby said:
memtest86,mate,and you will see the errors coming up soon :)
Yeah I just need to get my floppy drive working and I'll run it.
My CPU is an E6320 at 2.9GHz, I don't think that is the problem though. :[
edit: my computer just randomly rebooted. It's usually RAM that causes though right? >_<
