Zombu Mini
Consigliere
12 Jun 2004
SW17
Just wondering if anyone has one? What do you think?
http://www.zonbu.com/device/mini.htm
Processor: 1.2GHz, VIA C7 ULV
Intel-compatible, ultra-low energy use
Memory: 512 MB
Compact Flash local storage: 4GB
Graphics: VIA CX700M2 UniChrome PRO II, VGA output, supports up to 2048 x 1536 (16 million colors, 75 Hz)
Audio: built-in speaker, microphone and headphone ports
PC-compatible ports for keyboard and mouse
6 USB 2.0 ports
Ethernet: 10/100 Mbps built-in - broadband ready
Wifi: built-in 802.11b/g available as an option
Power Supply: 20 Watt AC-DC Adapter
Measurements: 4.875" x 2.175" x 6.675" or (124mm x 56mm x 170mm)
Weight: 2.1lbs (0.97kg)
$299.
But what would it actually be any good at with half a gig of RAM?
Well it would be like a EEE or something but without the screen...and it's running a form of Linux i think? So won't need as much RAM?
I don't know much about it - thought someone may have bought one who could explain more. :)
But why would you go for that over something like below which costs £175+ postage (which basically makes it the same as the zombu when you take into account import taxes etc) + free linux os. Yeah it may be a little bigger but you can add in an optical drive if you want and it has a lot more storage. Now iirc the atom is faster than the via c7 as well so you get an overall better machine.
Our Intel Mini-ITX Case, RAM & HDD Bundle consists of all you need to build a full Mini-ITX machine:
- Intel D201GLY2A D945GCLF Atom Motherboard with a 1.2GHz Celeron Atom 230 1.6GHz CPU
- Noah 3988 Mini-ITX Case measuring just 97 x 273 x 202mm
- 512MB 1GB of DDR2 667 RAM
- Seagate Barracuda 80GB 160GB 250GB 7200.10 3.5in SATA HDD 16MB Cache
- All required cables and adapters (including power adapter).
