ZoneAlarm not sharing MCE network
7 Aug 2004
Hey all got 2 MCE PC's, one used to run XP Pro and share folders fine, now it wont, if I turn off zonealarm it works, its set to med on trusted zone and says its sharing files etc, but its not, what gives ? what setting do i have to change?
I had the same problem with zonealarm a few months back. Nothing i did made any difference and sadly it had to be removed! Have you got the latest version?
hey done it now, yeah got latest, what i did was watch the log list when my other MCE PC accessed it, my local area network number got flagged up, i right clicked on it, and pressed allow, sorted, works fine now :cool:
Under Firewall > Zones
Add a new IP Range, add your LAN IP range (192.168.0.1 > 192.168.0.50) for example.
This will allow all sharing on your LAN.
