- 29 Oct 2002
I have this card. It's great, it really is. But, with small size and power hungry chip comes great heat. Great heat means needing more airflow, two fans and small heatsink mean MORE AIRFLOW at louder volumes. I have some questions:
1: The boost clock listed on their website states 1620 Mhz, yet I regularly see it spiking to ~1850ish, is this normal? Could this be underclocked/volted without too greatly impacting performance, I game at 2K @ 144Hz.
2: Short of full blown water cooling (which I'm considering at a cost vs new card trade-off), is there an astetically pleasing way of adding more cooling power to this card, but something that could be removed with little effort when I come to upgrade. I'm aware of the likes of the Arctic Cooling products, but they require attaching of RAMsinks and coolers to the mosfets, which looks very DIY, now what you want in a windowed RGB case.
3: A bigger case, and MOAR FANZ! Would this help or would I be pushing air for the sake of it? I currently have a 280mm rad in front, pulling air in, and the PSU + a 140mm fan venting, one top one bottom, fairly standard for a Fractal Mini C.
4: turning the PSU 180 degrees, so the extract is at the top, under the GPU, I'd have concern that this could starve the GPU of what little air it's already getting.
I upgraded to this card from a standard 1080 3-fan jobber, and the noise level difference is noticable, especially late at night. Just looking for pointers.
p.s. not sure if this should have gone under Graphics cards, but more related to cooling so here i r !!
Ta.
DB
Edit: forgot to state temps average out under load at mid 80's which I'm aware is "normal" for the Ti cards, in comparison the old non-Ti used to hit 58 degrees max.
Ta.
DB
