Hi,
I'm looking to purchase the Zotac Version of a GTX 1070Ti for my new rig and wondered what the difference was between the 3 versions on the Overclockers website were.
I can see that they all have a 5 year warranty, All three cards can do SLI, same outputs and mostly the same of everything else, there are a 3 fan version, 2 fan version and a Mini (also 2 fan).
The Mini version only requires a 1 x 8 pin input and has an power consumption of 150w.
The other 2 fan version has a 2 x 8 pin input and a power consumption of 230w.
The 3 fan AMP! version also has a 2 x 8 pin input although it does not mention power consumption.
Can someone advise what difference there is between the 3 regarding display? If any?
I guess the larger versions require more power and have a better ability to overclock? Would I see any difference in performance if all cards were stock?
Thank you in advance.
