Zotac GTX 980Ti AMP Edition - Displayport Issue?
15 Jan 2011
UK
Hi Guys,
Recently bought the Zotac GeForce GTX 980Ti AMP Edition from Overclockers, but have encountered a pretty rubbish issue, which is now starting to aggrieve me after spending over £500 on the card.. Ill try and explain the issue the best i can.
I have 3 monitors connected, Dell P2415Q x 2. I have both of them connected through Displayports, i also have a Samsung monitor up via HDMI for 3rd monitor.
The Displayports on my card some times dont detect the monitors. Even when I start up my PC with just one monitor connected to the Displayport, it does not work. Only the monitor connected to the HDMI are working fine. Black screen on anything connected to the Displayport, i can get the display ports to detect occasionally by turning the Dell monitors off at the wall socket then turning back on but this soon wears thin. I've switched around monitors and cables and am 99% sure it's only just the port, but I don't know if it's hardware side. I have the latest Nvidia drivers 361.43
I have read people say that they may all be interfering with each other and so the set-up doesn't work but then I question why even just one connected to that port doesn't work (with no others connected).
Any ideas ? I've contacted Zotac Support so hopefully they can respond with a solution, looks quite a common issue on the Nvidia forums on the 980Ti.
TW
