Hi all,
I have a Zotac GTX970 Dual fan model - https://www.zotac.com/us/product/graphics_card/gtx-970
The fan closest to the display ports started grinding like the ball bearings have gone.
Are fans in these things easy to replace and if so what fan would I need?
If not, can anyone recommend an new cooler for it?
It's annoying the hell out of me but i'd rather not spend a lot on it, i'd look to upgrade if it that was the case
Thanks for your help.
