ZOTAC H55-ITX WiFi
No reason it shouldn't - would be a very capable solution. Certainly as powerful as many top end systems if specced up well enough!
gt
Thanks
Was thinking of putting in an i3, an SSD and 4 gig or memory. Run from a Pico 150w PSU.
Would the Pico 150 be ok with it?
Lian Li PC-Q07B Mini-ITX Case - Black is the case i would choose. Pop it into that with a Pico 150w PSU and you would have loads of airflow, quiet pc and not a big footprint!
It's hard to be sure at this stage.
My intention is to run a motherboard much like this using a 150W pico driven from an adapter that offers 6A at 12V on three rails. Two rails attached to the pico psu, the third with a 4 pin atx adapter on the end supplying the majority of the cpu power requirements. I believe this will work at stock speeds, but that it may struggle with overclocking.
Overclocking options look very few and far between on this board based on the anandtech article linked above.
Gaaaaahhhh!
I really badly want to put together a mini ITX build in my old shuttle case, but I just cant justify spending the money on an extra PC I dont really need. :(
STOP TEMPTING ME WITH AWESOME LOOKING NEW PRODUCTS!!
PK!
Gaaaaahhhh!
PK!
Looks very impressive doesn't it!! :D
People normally use laptop ac adapters, since they take mains ac and output a fairly constant dc voltage. Shouldn't be hard to find a 12V one online though, all the places selling pico psus also sell the ac adapters.
Welcome to the forums.
