Hey Guys
I'm looking at pairing the Zotac H67 ITX mobo with a Streacom FC5 but I'm a bit confused after checking out the compatibility list for the case.
It states that the H67ITX-C-E is not compatible with the FC5, yet the H67ITX WIFI is? As far as I'm aware the H67ITX WIFI is the C-E model (used to be the A-E model but was revised?)
Does anyone know what actually changed between the A-E model and C-E model? and also is the A-E/C-E model the H67ITX WIFI model as the Zotac website suggests or something else?
Thanks in advance
Thanks in advance
