Zotac Infinity, Watercooling kit?!
Most people have more than one 120mm fan. You could always put it in the front of the case, or put the H50+ in the top and that on the back. Most cases come with these fan slots.
Like, put the larger dual fan H100 (?) in the top and that on the back. I'm sure that would work in a lot of cases.
By the looks of it, it would be;
1. A tight fit for most cases, the tubes extend out the back quite a bit.
2. You'll be stretching them tubes a bit if you put it anywhere on the rear of the case, so it must be designed to go somewhere in the front of a case.
They should have put the waterblock holes on the side and created better connections. Then it would be something cool!
It is quite neat though, looks like these closed watercooling loops are taking off.
Yeh front sounds like a good plan, shame they didn't post pictures with it in a case
Hmmm looking again, it does look like it's for the rear of a case going by those tubes coming from the card
this card is pointless, it will be like £500 and have bad cooling due to the single 120mm thin rad, oh and did I mention that it's **** ugly??
