- 31 May 2006
- Swansea
Hi,
I have a Zotac IONITX-A-B motherboard and I have a few (too many) questions.
When transferring over the Gigabit Ethernet, the sound will often stutter & the (USB) mouse lags/stutters - does anyone else with this motherboard have this problem? What could be causing it? Chipset limitations? Do you think an external USB soundcard would stop the sound stuttering issue, and if so which would you recommend (for a moderate price)? Would a USB-Ethernet adaptor help?
The other question I have relates to the BIOS. There is an option for "Stutter mode" in the BIOS which by default is set to Enabled. It is under the chipset options. Does anyone know what the function of this is as I can't tell a difference if operation with it enabled or disabled?
I have observed the sound stuttering/mouse lag issue with both XP SP3 (32 bit) as well as the 7100 build of Windows 7 (64 bit). I have 2GB of 800MHz RAM & a Samsung F1 1TB hard drive. The motherboard comes with the Atom N330 (Dual core 1.6GHz) processor which I have actively cooled with the supplied fan.
Thanks a lot!
Sticklyman
Thanks a lot!
Sticklyman
