Zotac is a good GPU comoany right?
19 Oct 2002
Found a
ZOTAC Gaming GeForce RTX 3060 Twin Edge OC 12GB GDDR6 192-bit 15 Gbps PCIE 4.0 Gaming Graphics Card, IceStorm 2.0 Cooling, Active Fan Control, Freeze Fan Stop ZT-A30600H-10M
I plan to get, the estore has 74& five star reviews on the estore I found it on.
;D misspelled cimoany
Found a
While I understood what you said, I don't understand if you are asking something or if you are just informing us that you are gonna buy one
I had a Zotac 780 Ti and it was a great card.
Can't speak for current cards though.
Are Zotav a Russian brand of GPU?
I think Zotav is a brand name for some sleeping pills.
A coworker and I were moaning about work for a bit today. It was a good comoany.
I've no idea how good a Zotac 3060 Twin Edge is, but if you can get one for Zotac's stated retail price of US$400 (which is £362 including VAT at 20%) then it's worth it. If you're being charged £600+, it's obviously not worth it. It's the bottom end budget card. Probably should be £300 tops. Because it's the bottom end budget card.
Zotac have a relatively long warranty on their cards, which is a good sign but not conclusive.
