I'm looking to upgrade my GPU to one of these Zotac's as they should fit my sff case. The only difference I can see between the OC version is a few MHz in boost clock (2490MHz vs 2475MHz). Is this important?
Will There be any upcoming deals on these GPUs you think? Funds are ready and I'm in no desperate rush to make the purchase if a better deal can be had.
OCUK25%OFF Code to celebrate 25years of Overclocker?s
https://www.**********/images/products/to/3579048.jpgZOTAC NVIDIA GeForce RTX 4070 SUPER Twin Edge OC 12GB GDDR6X Ray-Tracing Graphics Card, 7168 Core, 2490MHz BoostLN143751 | https://www.**********/images/products/to/3579044.jpgZOTAC NVIDIA GeForce RTX 4070 SUPER Twin Edge 12GB GDDR6X Ray-Tracing Graphics Card, 7168 Core, 2475MHz BoostLN143750 | |
Manufacturer | Zotac | Zotac |
Scan rating | Mid Range | Mid Range |
Chipset | GeForce RTX 4070 Super | GeForce RTX 4070 Super |
Edition | Twin Edge OC | Twin Edge |
Manufacturing process | 4 nm | 4 nm |
Microarchitecture | Ada Lovelace | Ada Lovelace |
Cores | 7168 | 7168 |
Core Clock | ||
Boost Clock | 2490 MHz | 2475 MHz |
Memory Size | 12GB | 12GB |
Memory Type | GDDR6X | GDDR6X |
Memory Clock | 21000 MHz | 21000 MHz |
Memory Bus | 192 Bit | 192 Bit |
Cooling Solution | Dual Fan (2) | Dual Fan (2) |
Included/Fitted Backplate | Yes | Yes |
Interface | PCIe 4.0 | PCIe 4.0 |
Connectivity |
GeForce VR Ready | No | No |
Multi-Way Graphics Support | ||
Microsoft DirectX Support | 12 API | 12 API |
HDCP Ready | Yes | Yes |
Max. Concurrent Displays | 4 Displays | 4 Displays |
Maximum Digital Resolution | 7680x4320 (8K UHD) | 7680x4320 (8K UHD) |
Real-Time Ray Tracing | Yes | Yes |
NVIDIA RT Cores | ||
NVIDIA Tensor Cores | ||
RTX-OPS | ||
Rays Cast | ||
Graphics Card Power Connectors | 1 x 16-pin PCIe | 1 x 16-pin PCIe |
Graphics Card TDP/Power | 220W | 220W |
Minimum Recommended PSU | 750 W | 750 W |
Maximum GPU Temperature | ||
Width | Dual Slot | Dual Slot |
Low Profile Support | N/A | N/A |
Dimensions | 234.1 x 123.5 x 40.2 mm | 234.1 x 123.5 x 40.2 mm |
