Looking to get a 1080Ti and noticed the Zotac's in stock, does anyone know if they are OK warranty wise in you replacing the heatsink or putting it under water?
Thanks
nope, and I wouldn't touch Zotac either.
Thanks
Hi not sure what the problem is with Zotac.
I have had a Zotac 980ti Amp since launch. Also nice to know that it has 5 years warranty. I know some people say you have to send it to Hong Kong. Which worst case could cost £25 after 3 years but surely this is better than an out of warranty one that you cant send anywhere.
£25 to hong kong sounds like its sans insurance which is a pretty risky proposition
Your retailer is responsible anyway so it would be cheaper to send it in and get them to RMA it for you in that case
Yes good point as you contract is with the supplier. Definitely better to have 5 years especially when they are hitting £800 now!
Only for I believe the first 3yrs in this case because the 5yr warranty is "a limited warranty". Normally (unless expressly stated) its only 12months and then you fall back on statutory consumer rights where you have to argue quality issues or have to deal with the manufacturer.
Guys you need to have your eyes open in these matters, just be aware and check your facts before splashing out with any trader and what's not in writing (email & digital comms now counts btw) is not worth anything.
Your contract is always with the retailer, you have 6 years from date of purchase to raise a claim that the goods were not fit for purpose or not of satisfactory quality - if its advertised as having a 5 year warranty and fails after 3-4 years then it isnt of satisfactory quality. The retailer can send the card off to the manufacturer and make you wait up to 28 days, but ultimately if the manufacturer messes you about its the retailer that has to fix it.
