ZOTAC Z68 POST diagnostics display codes
30 Nov 2008
London
The Zotac Z68 board has a two digit display, which is not mentioned the booklet which came with the motherboard.
I think it helps to locate failing componens on the board. I had a quick look on the zotac webpage but couldn't find any information about the error codes and what to expect if everything is working.
Has anyone seen such information, or have I missed something ?
Thanks
frank
Did you find anything out about this? Getting similar issues with it getting stuck on certain codes.
