stumbled upon this in my seach for a Amd fusion build.
Zotac ZBOX AD02/03
Model ZBOX-AD02-U
Chipset AMD M1 Chipset
Cooler Type Fan (Single Slot)
CPU Socket N/A (Integrated CPU)
Dimensions 7.40in x 7.40in x 1.73in - 188mm x 188mm x 44mm
Memory Size Up to 8GB
Memory Slots 2x 204-pin SO-DIMM
Memory Type DDR3 1066 SO-DIMM
Onboard Audio Onboard analog stereo high-definition audio/7.1-Channel LPCM digital audio (HDMI)/Optical Digital S/PDIF audio
Onboard LAN 10/100/1000Mbps, Wifi 802.11n/g/b (300Mbps)
Onboard Video AMD Radeon™ HD 6310
Package Contents 1 x ZOTAC ZBOX AD02
1 x VESA mount
1 x DVI- to-VGA adapter
1 x AC adapter
1 x Power cord
1 x Warranty Card
1 x User manual
1 x Driver CD
Power Connector DC19V
SATA 1 SATA (6.0 Gbps), 1 eSATA
USB 2 x USB 3.0 (back panel) 4 x USB 2.0 (2 on back panel, 1 on front panel, 1 on top panel)
Video Ports HDMI, DVI, VGA (via DVI-to-VGA adapter)
Warranty 1-Year Standard
http://www.zotacusa.com/zotac-zbox-amd-e-350-apu-1-6-ghz-dual-core-barebone-mini-pc-zbox-ad02-u.html
http://www.zotacusa.com/zotac-zbox-...apu-1-6-ghz-dual-core-all-in-one-mini-pc.html
Seems like they tick all the boxes for my needs, pica style psu, small case, same fuetures as the MB build ones, just no pci x16 (4) and other things cut awway i dont need, sould make less heat then too right!?
1.are they bad for BIOS/overall performance in the older build Zotac ZBOX they did !??
2. i guess i could put in a new bigger fan if needed !?? its easy access whit thumb screws like the side of a normal pc, access to all the hardware.
3. are external Blu rays like the Plextor PX-B120U 4x Slimline Externa loud spin noise vs a internal
http://www.overclockers.co.uk/showproduct.php?prodid=CD-049-PL&groupid=701&catid=10&subcat=494
4. what ram 4gb block for good speeds , in so-dim 1066 and is a 2.5 HDD like the Seagate Momentus 5400/7200 noisy, if so what sould i get then if not a SSD.
anyone having the older zboxes and can comment on build and bios /fan noise options, thanks
Zotac ZBOX AD02/03
Model ZBOX-AD02-U
1 x VESA mount
1 x AC adapter
1 x Power cord
1 x Warranty Card
1 x User manual
1 x Driver CD
