** ZOWIE MOUSE AND BUNGEE BUNDLES **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have got some serious support from Zowie on our new bundles meaning that a Premium Zowie gaming mouse is now in a bundle with a £21 mouse bungee with a huge discount.
This is an excellent saving on two great products which are colour coded to suit your style.
Zowie mice are the choice for pro gamers.
Zowie Mouse Bundle - ZOWIE AM Pro Gaming Mouse incl CAMADE - Black / Red @ £55.99 inc VAT
Zowie AM Pro Gaming Mouse:
The ZOWIE AM was developed for gamers who value stability, functionality and performance. As a competitive gamer, you should always be able to trust your equipment to perform at its best - if it does not, how should you? This is why Zowie only use proven technologies in our mice.
Specification:-
- Ambidextrous mouse developed by legendary CS-player Abdisamad 'SpawN' Mohamed
- Two thumb buttons on both sides to comfortably serve left- or right-handed users
- Easy to switch between left- and right-hand functionality, no drivers needed
- Optical encoder mouse wheel system for increased durability
- 450 / 1150 / 2300 DPI adjustment
- Adjustable USB report rate 125 / 500 / 1000 Hz
- ZOWIE custom-designed lens for a very low lift-off distance = 1.5 ~ 1.8mm
- Operating system: Win2000/XP/VISTA/7, Mac OS X v10.2 after Specifications:
- DPI (Dots Per Inch): 450/1150/2300
- Connector: USB
- Buttons: 5
- Length of cable: 2m / 6.6 ft
- Measurements: Length: 125 mm / 4.92 in Width: 60 mm / 2.36 in Height: 39mm / 1.53 in
- Weight: 88g (without cable)
Zowie CAMADE:
There are users who experience inconveniences with their mouse cable; whether it's due to space constraints, caught cable, or cable entanglement. the new Zowie CAMADE solves these issues.
Specification:-
- Weight: 240 grams
- Height (minimum / maximum): 8/11 cm
- Colour: Black / Red
Only £55.99 inc VAT.
ORDER NOW
Zowie Mouse Bundle - ZOWIE AM-FG Pro Gaming Mouse incl CAMADE - White / Grey @ £55.99 inc VAT
Zowie AM-FG Pro Gaming Mouse:
The AM is a series of ambidextrous mice that is unmatched by other mice in flexibility, stability and performance. The AM features two buttons on both sides which allows the user to switch between left- and right-handed usage. Only one side may be active at a time, thus eliminating annoying situations where you accidently hit the opposing side-buttons, resulting in an awkward situation, costing you a kill – or the game.
Specification:-
- Developed with inspiration from Abdisamad ‘SpawN’ Mohamed
- Easy to switch between left- and right-hand functionality, no installation needed
- Connector: USB
- Buttons: 5
Zowie CAMADE:
Specification:-
- Weight: 240 grams
- Colour: White / Grey
ORDER NOW
Zowie Mouse Bundle - ZOWIE FK Pro Gaming Mouse incl CAMADE - Black / Yellow @ £55.99 inc VAT
Zowie FK Pro Gaming Mouse:
The FK is similar to the AM in terms of specifications and features, and they are both ambidextrous mice developed for gamers who prefer a claw-grip play style, but that is where the similarities end.
Furthermore the FK features a new coating, which feels smooth and fine like regular rubber paint, but has increased resistance towards wear and tear. The coating helps increase grip for gamers with tendency to sweaty palms and it is easy to clean!
Specification:-
- PI (Dots Per Inch): 450 / 1150 / 2300
- Connector: USB
- Buttons: 5
- Length of cable: 2m / 6,6 ft
Zowie CAMADE:
Specification:-
- Weight: 240 grams
- Colour: Black / Yellow
ORDER NOW
