ZyXEL router not accepting new devices.
Caporegime
4 Jan 2011
Hi,
Basically my ZyXEL wireless won't accept any new devices to the network, it can be detected but the connection always fails, devices that currently are set up work fine with it.
Just for example, laptops and ipad is working fine on the internet.
Recently got a new phone it wouldn't connect, my old phone would until i wiped the memory now it will also not connect, also did a third try by deleting network of my 3ds and tried reconnecting with it and it also cannot connect.
Anyone got any clue why this is happening? Should i hit the factory reset button on the router (really dumb with this stuff and scared to do so as parents use the VPN service to their work).
And as a side note to the thread i use homeplugs to get my internet downstairs but it randomly cuts out every now and then and the lights go off on the homeplug and requires me too unplug and replug it in, seems to happen 3-4 times a night now.
Any suggestions welcome, Thanks.
Have you logged into the router and looked at the settings? It's quite possible that it could be configured so that new devices need manually authorising before they can connect.
Have you rebooted it?
One of our clients had a zyxel wireless router that did exactly the same, never found a proper solution unfortunately.
