Useful Overclocking Applications
31 Oct 2007
Luxembourg
How can I get speedfan to startup when I boot my pc?
I can't find it in the options.
most programs have something enabled that allows you to start it when logging into windows
Caporegime
OP
6 Dec 2005
Birmingham
I shall update the thread once I get back with my food. :)
is the ati tool reliable?
I use it to scan artifacts, and I can get my core from my 8800GT on 745/2100 without artifacts.
I only use it to monitor temps really.
Run 3DMark 06 and play some games to test out graphics overclocks I do.
5 Aug 2006
im using cista x64 hacked core temp,
i assume its totally reliable? reason i ask is becuase it says Processor: "Intel Pentium E2140 (Conroe-2M)"
i was under the impression that it should be labbled Conroe-1M not 2?
and my temps are a bit toasty lol. me thinks i need an aftermarket cooler tbh!
26 Sep 2007
Euhm, I want to know how I can get speedfan to start when I login to windows.
I hate having to open it every time to put the fan speed on 75% manually.
I think there's an option in Speedfan for this, else but paste a shortcut into your Startup folder.
