E46 - Remove Gear knob to fit Gaiter
17 Sep 2003
Suffolk
Hello Guys,
I'm trying to remove the gear knob on my BMW E46 but am having some problems removing it, does anyone have any experience as to how this is meant to come apart?
I need to fit a new Gaiter as my old one has some holes in it!
Thanks,
Michael
mjt
mjt
31 Aug 2007
aye pull
the one in our e39 worked itself loose, i used to pull it off all the time :o
it was actually suprisingly heavy :eek:
Man of Honour
29 Jun 2003
Wiltshire
It is a pain to get off :p I changed mine for a black one. Are you doing the handbrake too? Did both of mine and really makes a difference :)
Permabanned
29 Mar 2006
Manchester, UK
attachment.php
:p
Man of Honour
18 Oct 2002
South Coast
Bit of a bump but anyone know how to remove the handbrake gaiter? I'm replacing the gearbox and handbrake gaiters, already done the gearbox one but can't figure a way around the handbrake one.
Before anyone says it, no I haven't replaced it with ass ones, I've replaced it with new black Italian leather ones, looks exactly like the original, just smells of sweet Italian leather and feels so soft ^_^
Edit*
Never mind, sorted it!
18 Oct 2002
Must be a BMW thing as it's the same in the E60.
I had to replace mine because the clips that hold it in had broken.
It's a bit disconcerting when you're going for a quick change and the gear knob literally comes off in your hand. :eek:
