New sidelights: Much better! (Also, Xenon VS Halogen)
27 Nov 2004
North Beds
Hey guys,
As per my thread about 2 weeks ago i ordered some white sidelights, and unfortunately was off work for a week with a trapped nerve in my spine and they were delivered to my work premises, so no playing (not that i couldve) until i went back to work today and recovered them!
I went for the PIAA Xtreme White bulbs in the end, as PIAA say they are the closest colour to xenon.
So here's a quick compare:
As if i have to say, the normal ones are on the left :p
Much closer match to the dipped beam colour now
Also, BMW might be awkward with somethings, but my god this was the easiest sidelight change ive ever done! Literally just open bonnet, 1/8th turn on holder, pull, replace bulb, and put back in, 10 seconds max.
Also thought i'd show the difference between low beam, a halogen main beam and xenon main beam:
Xenon Low beam
Halogen Main beam (for flashing people etc)
Xenon Main beam (when you put the stalk forwards)
Look at the top and edges of the images mainly to see the difference!
Slightly hard to appreciate just how much more light is put out by the xenon high beam compared to the halogen in these pictures though, on an unlit country road it's like having a portable sun strapped to the bonnet :D
Tom.
OP
27 Nov 2004
North Beds
Still burning oil like an Iraqi insurgent?
:p It's going back to the specialist i bought it from in the 2nd week of august as i'm down there, it's using it very steadily and there are no leaks or smoke :s They think it's the valve stem seals but need to see it to know really.
11 Dec 2004
I've got the same sidelights, they cost a tenner off ebay and they are great. They make such a difference to how the car looks, especially with just the sidelights on.
Those comparison pictures are excellent by the way.
Man of Honour
18 Oct 2002
South Coast
Can't wait to get mine now! should be here tomorrow :) now the front will look as good as the LED rear in the dusk!
As for your other pics of the modes, I just tried this in front of garage door and wondered if you could check something on your bi-xenons too when you get a chance mate, on mine when I enable "Xenon Main beam (when you put the stalk forwards)" my halogens also turn on but they don't have any priority brightness, they are the same brightness as the 'flasher' mode (stalk backwards) whilst the xenons increase in brightness at the same time which is capable of signalling Batman by the looks of it.
Basically what I wanted to know is if your halogen bulbs also come on (as well as the bixenons) when you push the stalk forwards ?
Might be worth me changing the halogens for ultra white H7s as well just to make all the bulbs as white as the xenons :p
Man of Honour
17 Oct 2002
His dipped and main are HID. His sidelights are halogen. His other main is halogen becuase Xenon doesn't warm up quick enough to flash your lights at people.
4 Nov 2003
Ashford
Do you know why it does on newer cars? Because early E60s had bixenon and a halogen lamp, where later ones even flashing the lights is done by the xenon lamp(with no warm up problem).
OP
27 Nov 2004
North Beds
tbh i dont actually notice any delay when turning my main beams on, it's more it massively reduces the life of them if you turn them on and off frequently. Perhaps technology has improved so that they arent as affected?
Man of Honour
17 Oct 2002
No idea. Come to think of it an E90 I had once didn't have a Halogen flash either. Perhaps they've developed them a bit better now?
24 May 2004
Xenons uses Xenon bulb for low beam and Halogen for mainbeam, Bi Xenon uses the Xenon bulb for both low and main beam controlled using a motorised shield/reflector to adjust the different light pattern coming out of the headlamps afaik.
