The X243H is a large 24” Widescreen 16:9 format display which brings a perfect balance of best value performance with full high definition technology supporting the latest requirements for digital home media and cinematic applications. Thanks to the 16:9 format cut you can view your photos or movies over a broader cinematic area for a thrilling experience. The X243H full high definition display supports the latest Blu-ray devices for True HD digital content with a dramatic visual impact for entertainment and multitasking.The X243H is a brilliant display reproducing crisp data and media over a cinematic format with the added benefits of a higher resolution performance. In addition, the aesthetically pleasing design portrays a contemporary style that easily compliments any home or work environment.
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 40000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 176°/176°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 578.5mm x 423.1mm x 201.9mm
- Weight: 7.8kg
- Warranty: 3 Years Collect & Return
Just £166.99 Inc. VAT
BUY NOW
