But you use cruise control and the lie of the terrain with how agressive cruise chases the target speed can greatly effect fuel economy.
Because if you slowly came to a stop using engine braking, then you would not have been using fuel for that last few hundred yards...
So when you press the brake you dont lift off the throttle anyway and get fuel cut.... ?
The difference isnt marked if you brake to a stop, the issue is heavy braking means you have to get to a slower speed to avoid stuff ahead etc so you have to accelerate more, ie from 10mph rather than say 18? I see it all the time with cars ahead of me. Our average speed is no different as we get the places at the same time but they do a lot more braking, over brake and more accelerating.
Cos you spend more time prior to the braking maintaining speed rather than utilising engine braking under fuel cut conditions. Also generally results in overbraking that reading the lights.
You are saying the same thing as me, thats just another scenario. In all examples it means that you are on the gas for a longer time.
No idea what cruise control has to do with that last example by the way, that is completely irrelevant to what i was saying.
The problem with the "Aggressive braking" answer is that it must depend on the situation.
If you have a limited view ahead and you have to stop, releasing the accelerator alone probably isn't going to slow you down in time (the majority of cases IMO). So if you're using engine braking anyway, what difference is there going to be between braking early for longer or leaving it until the last minute?
Whatever the mechanical reason (of which i have absolutely no interest, just as i have no interest in fuel consumption in general) the answer is a nonsense one.
I think your just struggling with some sort of document or process that exists somewhere that conflicts with your personal opinion, which is pretty typical isn't it?
I have to agree. Answer B makes sense if you are driving at a speed and encounter traffic, which is what happens in real life. Answer C is only correct if harsh braking is not matched by the harsh acceleration which most people would use if they were rushing around in the car.
B obviously, thats just common sense for theory.
Braking aggressively = braking late.
Good fuel consumption is about planning every move early.
Both of those are making assumptions about the situation though. Harsh braking in itself doesn't cause increased fuel consumption, which is what the question is asking.
Smooth driving in the real world does help but emergency stopping wont use any more fuel then deciding to hit the child/pet while slowing more gently.
But the question is clearly misleading! It is supposed to be a test to help teach someone to drive and is not only misleading but factually incorrect!
No, its not. You are mis reading the question. It does not mention 'aggressive driving', or 'aggressive acceleration'. Aggressive braking has absolutely no effect on your fuel consumption.B obviously, thats just common sense for theory.
You can gently brake from 60 to 40 or you can aggressively brake from 60 to 40. Either way, it wont change your mpg.
