First we had the deal on the standard version and now we've gone one better. The LED version offers improved colours and darker blacks for improved image accuracy. At only £149.99, in my opinion it's an absolutely bargain with DVI connectivity as well.
BenQ G2420HDBL 24" Widescreen LED Monitor @ £149.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
- Warranty: 3 Years On-Site
Only £149.99 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 4.4kg
ORDER NOW
