BENQ G2420HDBL 24" LED MONITOR ONLY £149.99
17 Oct 2002
Stoke
First we had the deal on the standard version and now we've gone one better. The LED version offers improved colours and darker blacks for improved image accuracy. At only £149.99, in my opinion it's an absolutely bargain with DVI connectivity as well.
BenQ G2420HDBL 24" Widescreen LED Monitor @ £149.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
- Warranty: 3 Years On-Site
Only £149.99 inc VAT.
ORDER NOW
11 May 2008
UK
We will be holding the price. :)
drop it, and hack an hdmi port onto it and I'll buy 3 ;) oh, and throw in the active DP adaptor :)
hmmm, maybe you actually should do something like that, make bundles of 3 monitors that would work with eyefinity (either with adaptor or inbuilt dp) with a little discount :D
