SiteCom WL-585 Wireless N Modem Router 300Mbps Bundle *EXCLUSIVE OcUK Deal* @ £88.99 inc VAT
Create a high-speed wireless network with speeds up to 300 Mbps and connect with ADSL internet, Use this Wireless ADSL 2+ Modem Router 300N X3 to set up a wireless home network with superior throughput and an unparalleled wireless range. This Router enables you to wirelessly share files and broadband Internet access, as well as the peripheral *devices attached to the PC’s in your network.
- Up to ADSL 2+ compatible
- 802.11b+g+n (draft 2.0) Wireless Standard Protocol
- Wireless speeds up to 300 Mbps
- 802.3, 802.3u 802.3a-t Security: WEP 64 & 128 bits, WPA-TKIP, WPA-AES, WPA2, WPA-Radius
- Compatible with Dynamic IP, Static IP, PPPoE and PPTP internet connections
- Three internal antennas
- Quality of Service (QoS)
- Universal Plug & Play (uPnP)
- Application Layer Gateway (ALG)
- Access point disable functionality
- ISP selector
- ON/OFF button
- 10 Year Sitecom Direct Warranty
Only £88.99 inc VAT.
ORDER NOW
- ISP selector
- ON/OFF button
ORDER NOW
