Another leaked driver, only this time newer than everything else out there in build date and version numbers.
D3D - 8.14.10.0755 - 5 builds newer than the 10.5 v1 betas, 15 newer than 10.4b betas
OpenGL - 6.14.10.9827 - 1 builder higher than the ogl 4.0 betas giving these opengl 4 support as well
2D - 8.01.01.1031 - highest build to date so the newest 2D version
So that makes these the current latest build in all 3 areas, which makes a nice change lol.
If your using the 10.5 beta's uninstall before using these to avoid problems, same with the 10.4b beta's just incase. (via the catalyst uninstall utility, no driverclean garbage)
http://www.megaupload.com/?d=0UTSKFBK
