A quick couple of questions, if you do not use CCC, just the drivers themselves, does the card still downclock itself in 2d (and if so to what value) ?
Would the above method of changing the xml be able to overide CCC's overclocking limit ?
Nice write up Dancer, i assume you've had no more problems since this fix. I may explore this avenue myself as i am currently the victim of the overclocking and dual monitor screen flicker issue. As the issue is caused by the 2d clocks dropping too low for 2 monitors this may be a viable option to get around this if the new beta drivers don't work for me.
I got this from the AMD forums..
"Manually forcing the fan to run at 60% pretty much took care of my problem as well. However, as I mentioned above, I don't think it's because the driver isn't auto-adjusting the fan speed. I believe it is, but it's adjusting it to keep the GPU chip cool, which is where the card's temperature sensor is. I think the problem is that other chips on the board are getting hotter than the GPU (or hot enough to become marginal), but the fan doesn't kick in yet per auto-adjustment because the GPU chip's temperature isn't hot enough yet. By forcing the fan to 50% or 60% all the time, rather than peg it to the GPU temperature, ALL the parts on the board are getting cooled all the time, including aux or memory chips that are more temperature sensitive than the GPU itself."
I have updated my bios the latest version. That helped a great deal with only two crashes since then. Lately I've also manually adjusted my fan to 50%, crashes are very few. However this remains to be seen...still testing.
By the way I have a single 19" monitor at 1280x1024
I hasn't worked. It was most of the night, then I had a major crash and my fans went wild. This was without using your ccc profile method.
I will go back and try that again. I had notice the GPU was at permantently 100% activity. Can that be right or have I set that profile up wrong? I got the info from GPU-Z.
These steps are from the AMD forums. The values below are suggested by others (I use slightly higher clock speeds), but others have reported using much higher voltages than me. Keep an eye on your gpu temps as well (for example by using gpu-z) and if it gets very hot try setting the fan to manual in the profile and set the fan speed to somewhere between 50-90% (whichever keeps it nice a cool). What is too hot is open to debate. My card is typically in the 50s and low 60s when in use, but 70s are reported as fine by some (check official documents for your gpu heat tolerance).
1. Open CCC
2. Unlock and Enable Overdrive if not already done.
3. Go to Options/Profiles/Profiles Manager. Create a new profile. Under composition make sure “ATI Overdrive” is checked. Save and Close, DO NOT ACTIVATE.
4. Go to: C:\Users\{yourusername}\AppData\Local\ATI\ACE\Profiles (you will need to have “show hidden files” turned on for this)
5. Open the xml document with the name of the profile you just created (notepad is fine)
6. Change the values of the Clock and Memory speeds to look like this (these specific values are what worked for me and my card, use judgment) EDIT ONLY THE BOLD VALUES.
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="40000" />
<Property name="Want_1" value="60000" />
<Property name="Want_2" value="85000" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="90000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="120000" />
</Feature>
<Feature name="CoreVoltageTarget_0">
<Property name="Want_0" value="1000" />
<Property name="Want_1" value="1010" />
<Property name="Want_2" value="1010" />
</Feature>
7. Save and close. Go back to CCC and activate the profile you just created.
Good luck.
So you've not connected your motherboard properly, and you've not provided sufficient voltage to your cpu. And you're asking if those might be problems?
hi
thanks for the fix info. I am going to try this as I have had lots of display not responding errors on my 2x HD5770's
I wanted to ask, do I need to select the new profile manually each time I go into windows, or will it be loaded automatically when windows starts?
Also must ATI overdrive be enabled? ( I disabled this to be on the safe side)
cheers
