Xenon AMD Athlon X2 255 3.10GHz Bundle - Dual Core @ £139.99 inc VAT
Designed by experts the "Xenon AMD Athlon X2 255 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Athlon X2 255 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Althon II X2 255 3.10GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: GEIL Value (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £139.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core @ £164.99 inc VAT
Designed by experts the "Xenon AMD Phenom II 840 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 840 Bundle" offers you speed and silence in perfect combination.
- CPU: AMD Phenom II X4 Quad Core 840 "95W Edition" 3.20GHz
Service Package
Only £164.99 inc VAT.
ORDER NOW
Designed by experts the "Xenon AMD Phenom II X6 1055T Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X6 1055T Bundle" offers you speed and silence in perfect combination.
- CPU: AMD Phenom II X6 Hex Core 1055T 2.80GHz
Service Package
Only £239.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
