***Official Unigine Heaven DX11 3.0 Benchmark Scores***
6 Oct 2007
North West
Excellent. Thanks for pointing it out - I would have been none the wiser otherwise!
I haven't changed the fan speed manually, no.
Its been said by some sites that higher temps can effect overclocks and cause clocks to throttle a little. When benching try using a manual fan speed of say 85%, you never know you may improve your results.
3 Feb 2012
Peterborough
I tried and it didn't change my score. I'm interested to find out what I can do better because it looks like some people are getting better scores than me with smaller overclocks and the same CPU.
25 Jun 2011
Aberdeen
Every time I take a screen shot and paste it out I just get a black print? any ideas or am I doing something seriously wrong? Tried both F12 and print screen, same result?!
OcUK Staff
20 Feb 2012
John Smiths Stadium
I am gonna try this test again with 2700K and Ivy 3770K on ASUS Max V gene Wednesday with some serious CPU and DRAM clocks and see if CPU clocks make a difference.
18 May 2003
At 1080p with the OP settings I get 80.7fps 2032 (min 38.9, max 174.9)
That's with the 680@ 120% power, +140 core and +500 mem
Currently my CPU is at stock 3.2Ghz so I guess I'd see some improvement when I spend the time to clock it to the 4/4.5Ghz it's capable of
Caporegime
24 Sep 2008
Essex innit!
What is strange with mine is, when my cpu is @ 4.6 I have no problems and play games fine but as soon as I run 3Dmark11, fail!
Works ok @ 4.4 though. Just seems strange that the cpu test gave me the BSOD yet is fina at all other times.
OP
5 Jan 2007
Smallbrook
Scores updated!
AMD 7970 takes the lead with a huuuuge result from 8 Pack !!! Well done... can the GTX680 take back the crown????
Here is my submission.
Sapphire 7970 @ 1375, 7700.
3930 @5.1ghz G. SKill 16gb DDR3@2450 10-12-12-31.
ASUS R4E
Not sure how to get the link for validation ??? anyone please????
Just fill in the details on the page you have screenshot and hit submit and it will be emailed to you :) !
Can you confirm the voltage you are running please as well 8 Pack?
