*** This Week Only 11/04/2012 ***
8 Sep 2003
150 yds from OcUK
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - OEM @ £41.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 1yr Warranty
Was £49.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) Processor - Retail with FREE Deus Ex PC Game @ £185.99 inc VAT
We call it the new AMD FX 8-Core Processor Black Edition and it's unlocked for your overclocking pleasure.1 Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor featuring the all-new "Bulldozer" architecture. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed with easy-to-use AMD OverDrive™ and AMD Catalyst Control Center™ software suites. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
- Multiplier Unlocked
- Eight Core Technology
- 3.60GHz Clock Speed
- 4.20GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 125W
- Voltage: 0.9375v - 1.4125v
- 32nm technology
- Integrated memory controller upto 29.8GB/sec
- Support upto 1866MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was £199.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** @ £119.99 inc VAT
Dominator memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you’ll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you’re an experienced overclocker, you can always adjust the settings on your own to push for even higher overclocking performance.
State-of-the-art cooling efficiency is essential for high-performance memory. Our DHX+ technology uses specially designed, high-quality heatsinks and a custom-designed PCB that cools the front and rear of the DRAM chips as well as the printed circuit board itself.
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
Features:-
- Ultra-high performance 16GB (4x 4GB) Domintaor® quad kit with Intel XMP 1.3 profile
- 16GB total capacity provides ample headroom for the most demanding user
- Outrageously fast 1866MHz performance.
- Ultra-low 9-10-9-27 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50-1.60V
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £119.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Was £131.99 Inc. VAT
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £29.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £35.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £52.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £55.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
OcUK Value 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit @ £23.99 inc VAT
OcUk Value Series Memory is designed to optimized the high performance DIMMs for reliability in order to ensure your system does not fail you resulting in great performance, compatibility and reliability.
Features:-
- Cas latency: 9-9-9-24-2N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1333 (PC3 10666)
- Test voltage: 1.5 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
Was £29.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
OcUK Value 8GB (1x8GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module @ £35.99 inc VAT
Features:-
- Capacity: 4GB (4GBx1)
Was £37.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was £429.95 Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £329.99 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
VTX3D HD 7850 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game @ £182.39 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1024
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FREE Dirt3 PC Game download voucher
Was £194.99 Inc. VAT
Only £182.39 inc VAT.
ORDER NOW
Sapphire HD 7870 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The new SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN graphics processing architecture.
The Sapphire HD 7870 GHz Edition is equipped with 2GB of the latest GDDR5 memory clocked at 1200MHz (4.8Gb/s effective) with the new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 1000MHz
- Processing Cores: 1280
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 2 Years
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £339.95 Inc. VAT
ORDER NOW
Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card @ £341.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £349.99 Inc. VAT
Only £341.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 750MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £239.99 Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 1024MB GDDR5 PCI-Express Graphics Card @ £167.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 835MHz
- Memory Clock: 4050MHz (Effective)
- Shader Clock: 1670MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £169.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560Ti "Phantom" 2048MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
Features:-
- Core Clock: 822MHz
- Shader Clock: 1644MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £219.95 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 560 2048MB GDDR5 PCI-Express Graphics Card @ £161.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Processing Cores: 336
- Shader Clock: 1620MHz
- SLI Ready
- HDCP Capable
- OpenGL 4.1 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 years
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card (015-P3-1480-KR) @ £179.99 inc VAT
Next generation gaming has arrived. Nvidia GeForce GTX 480 gives your games an adrenaline shot with the world's fastest performance and futuristic, visually stunning graphics. Experience heartpounding, cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jawdropping stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 480: pure adrenaline meets visual bliss.
- EVGA Precision Tuning Utility
- Core Clock: 700MHz
- Memory Clock: 3696MHz (Effective)
- Shader Clock: 1401MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 years standard warranty
Was £184.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) @ £115.19 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 867MHz
- Memory Interface: 192-Bit
- Shader Clock: 1734MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years (If registered within 30 days of purchase)
Was £119.99 Inc. VAT
Only £115.19 inc VAT.
ORDER NOW
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black @ £119.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Was £124.99 Inc. VAT
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
BenQ RL2240H 22" Widescreen LED Monitor - White @ £107.99 inc VAT
The RL2240H is a professional gaming monitor suited for RTS game play. Co-designed with the renowned StarCraft II team, StarTale, this 21.5” LED backlight monitor is packed with the latest features: the Black eQualizer, RTS mode, Display mode, Smart Scaling, 2ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Built to set the benchmark for RTS gaming monitors, the RL2240H is a true testament to the belief that 'gaming is in the details'. Each and every feature has been meticulously thought out and created together with the renowned StarCraft II team, StarTale, to provide RTS gamers with vital visibility and command to take their performance to new heights.
The collaboration successfully brought together prominent players from StarTale and tapped into their wealth of knowledge and insights to create the ultimate gaming monitor that can handle real-time strategy games. Professional gamers like Rainbow, July, Ace, Bomber, Squirtle and Virus provided BenQ with insider perspectives on details that were essential to winning a game. The recent achievements from individual StarTale gamers include winning Clash of the Houses, IEM World Championship, Intel Extreme Masters Season 5 and GSTL league play.
The Black eQualizer is an exclusive feature that meets the demands of gamers when it comes to unprecedented level of control and visibility. Via finely designed color engine technology, dark scenes are brightened without over-exposing white levels, allowing gamers to acquire critical combat details and information and react quickly. Don’t let poor visibility and judgment cost you the game.
During product development and testing stages, BenQ's product team and the StarTale players exchanged several visits to fine-tune the display performance of the RL2240H for better accessibility and comfort. What they came up with is the preset RTS mode that automatically adjusts your monitor calibrations accordingly for optimum RTS gaming. This out-of-the-box setting allows you to see your enemies more visibly among the distractions and darkened areas. See what the professional gamers see and get the competitive edge you need with optimized color and contrast exposures. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between four different screen sizes from 17", 19" and 19"W to 21.5" using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 2ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of sluggish display.
The RL2240H comes in a sleek white housing that was favored by StarTale_July. Be the envy of all the other gamers as you sport the RL2240H with fluid lines and distinct curves.
Features:-
- Screen Size: 21.5”W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Brightness ( typ.): 250 cd/m2
- Contrast ( typ. ): 1000:1
- DCR (Dynamic Contrast Ratio) (typ.): 12M:1
- Viewing Angle (L/R;U/D) (CR>=10): 170/160
- Response Time(Tr+Tf) typ: 2ms GTG
- D-sub/DVI/HDMI/Headphone Jack
- 2yr Warranty
Was £113.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Brightness: 300cd/m²
- Response Time: 2ms
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was £129.95 Inc. VAT
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £143.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 120 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 120Hz refresh rate and 2ms tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Response Time : 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
BenQ G2750 27" Widescreen LED Monitor - Black @ £179.99 inc VAT
An enjoyable addition to your everyday home or work life, the G2750 gives you crisp and accurate viewing at all times. The G2750 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. The G2750 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money. The G2750 has passed Windows® 7 certification and are fully compatible with Windows® 7 color systems. Plug in the G2750 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
- Screen Size 27"W
- Resolution (max.) 1920 x 1080
- Pixel Pitch 0.276 mm
- Brightness 300 cd/m2
- Contrast Ratio 1200:1
- DCR:50,000:1
- Response Time (tr/tf) 5 ms
- Display Area 597.6 x 336.15 mm
- Display Color 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
- Terminals D-sub / DVI-D
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 205
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 52W (max)
- Auto Switching Power Supply Built-in
- Features Senseye® Human Vision Technology (plus Senseye 3)
- HDCP Support
- OSD Language: 17 languages
- Windows 7® compatible
- K locker: yes
- Adjustments Tilt (down / up) -5 / 15
- Dimensions (HxWxD) 488.5 x 654.4 x 191.2 mm
- Weight Net weight: 6.4 kg.
- Gross weight: 8.12 kg.
- Accessories (Standard) VGA
- Product Colour Glossy Black
- Vista Certification Premium
- VESA Wall Mounting 100 x 100 mm
- 2yr Warranty
ORDER NOW
MSI CR640-066UK 15.6" HD, Intel Core i3-2310M, 2GB DDR3, HDMI Laptop, Windows 7 Home Premium Edition Laptop - Silver @ £395.99 inc VAT
nonl2br
<b>Processor</b> Intel® Core™ i3-2310M Dual Core (2.1GHz, Intel Sandy Bridge Architecture, 3MB Cache) <br>
<b>Screen</b> 15.6" (1366 x 768 HD Resolution) <br>
<b>Operating System</b> Windows 7 Home Premium Edition 64-bit <br>
<b>RAM</b> 2GB (DDR3 1333MHz) <br>
<b>Hard Drive</b> 320GB <br>
<b>Optical Drive</b> DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi) <br>
<b>Graphics</b> Integrated (Intel® HD 3000 Graphics with up to 1274MB Shared Memory) <br>
<b>Wireless LAN</b> Wireless (802.11b/g/n Wireless) <br>
<b>Network Card</b> 10/100/1000 Gigabit Fast Ethernet <br>
<b>Integrated Webcam</b> Integrated Webcam with Microphone <br>
<b>Card Reader</b> 5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card™) <br>
<b>USB Ports</b> 2x USB 2.0 ports <br>
<b>Speakers</b> Integrated Sound System <br>
<b>VGA Port</b> 1 External VGA Port <br>
<b>Charge Time</b> 2.5 Hours <br>
<b>HDMI</b> 1x HDMI Port <br>
<b>Warranty</b> MSI 1 Year Collect & Return Warranty <br>
<b>Battery Life</b> 5-6 Hours (up to 6 hours with power management) <br>
Was £407.99 Inc. VAT
Only £395.99 inc VAT.
ORDER NOW
OcUK Tech Lab - V8 Watercooling Kit 240 @ £190.18 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £194.98 Inc. VAT
Only £190.18 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooled Case - BitFenix Shinobi XL Full Tower - Black @ £423.58 inc VAT
nonl2brAssembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money! </br></br>
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.</br></br>
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.</br></br>
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range</br></br>
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.</br></br>
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.</br></br>
<strong>PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU</strong></br></br>
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.</br></br>
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)</br>
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX</br>
- 5.25” Drive Bays: x 5</br>
- 3.5” Drive Bays: x 7</br>
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)</br>
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)</br>
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)</br>
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)</br>
- Cooling Bottom: 2 x 120mm (optional)</br>
- PCI Slots: 9</br>
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio</br>
- Power Supply: PS2 ATX (bottom, multi direction)</br>
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking</br>
- Maximum CPU Cooler Height: 193mm</br>
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)</br>
- Maximum MB Tray Clearance (rear): 34.5mm</br></br>
<strong>Component List:</strong></br></br>
1X BitFenix Shinobi XL Full Tower Gaming Case - Black</br>
The brand new king of watercooling cases offering excetional hardware layout options and space for expansion, this case is futureproof to the next level!</br></br>
1X Hardware Labs Black ICE SR-1 360 Radiator</br>
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.</br></br>
1X EK Supreme HF CPU Waterblock - Copper Plexi</br>
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!</br></br>
1X Alphacool Laing D5 Vario Pump 655</br>
The Best watercooling pump on the market. Needs little introduction.</br></br>
1X Alphacool HF D5 TOP - Black Acetal G1/4</br>
The ultimate top for your pump offers even better performance as well as more mounting and connective possibilities</br></br>
1X Phobya Single 5.25” Bay Reservoir</br>
Single bay reservoir for installation into the 5.25" optical drive bay.</br></br>
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish</br>
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.</br></br>
1X XSPC 7/16" ID [16/11mm] High Flex Hose - Clear</br>
High quality watercooling tubing with a superb bend radius</br></br>
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans</br>
The most recognised performance fans for watercooling radiators.</br></br>
Supported sockets:</br>
- Intel Socket 775</br>
- Intel Socket 771</br>
- Intel 1366 Socket</br>
- Intel 1156 Socket</br>
- Intel 1155 Socket</br>
- Intel 2011 Socket</br>
- AMD Sockets: 939, 754, 940</br>
- AMD Sockets: AM2, AM2+, AM3</br></br>
<a href="http://www.techpowerup.com/reviews/Bitfenix/Shinobi_XL/" target="_blank"><img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/tech_powerup_recommeded.jpg"></a>
</br></br>
***NOTE***</br>
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.</br>
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.</br>
Custom Units can take 24 to 48 hours if assembly of a component is required.</br></br>
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.</br>
Was £425.98 Inc. VAT
Only £423.58 inc VAT.
ORDER NOW
Plantronics GameCom 780 7.1 Surround Sound USB Gaming Headset @ £38.78 inc VAT
The Plantronics GameCom 780 USB headset with Dolby technologies transforms standard audio into a stunning 7.1 surround sound experience.
The noise-cancelling microphone kills background noise so your commands are loud and clear. When you need to take a break, built-in spin joints let the earpods lay flat for easy storage.
Need to adjust volume? No problem. The controls are right on the earpods so you'll always have eyes on.
The GameCom 780 is built to last with superhero-strength cords and joints; ultra-comfortable ear cushions and headband let you stay in the game for as long as it takes.
• Dolby Headphone and Pro Logic IIx technologies transform standard audio into a stunning 7.1 surround sound experience
• 40mm speakers pound out deep bass and immersive stereo sound
• Built-in spin-joints let the earpods lay flat for easy storage when you need to take a break
• Noise-cancelling microphone kills background noise so your team or opponents can clearly hear your commands
• Easy-to-reach on-ear volume and mute buttons let you adjust the sound and still keep a hand on the controls
• Superhero-strength cords and joints mean this USB headset will be around for all your battles
• Ultra-comfortable ear cushions and headband make the GameCom 780 perfect for gaming, and great for watching videos, listening to music, and making PC voice calls.
Was £39.98 Inc. VAT
Only £38.78 inc VAT.
ORDER NOW
Logitech G35 Gaming USB Headset PC 7.1Ch Surround Sound @ £89.76 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
- 2-years limited warranty
Was £90.98 Inc. VAT
Only £89.76 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £40.79 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £49.99 Inc. VAT
Only £40.79 inc VAT.
ORDER NOW
Steelseries Siberia v2 Gaming Headset - Green (51120) @ £67.58 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Was £69.98 Inc. VAT
Only £67.58 inc VAT.
ORDER NOW
TT Esports Shock One 5.1 Headset @ £53.98 inc VAT
The Shock One is designed with performance and comfort in mind, featuring DTS 5.1 channel virtual surround sound, dynamic 40mm speaker drivers, a leather headband pad and multiple ear-pad cushions for enhanced comfort. The new headset has a black and red color scheme, complete with an illuminated Thermaltake logo. The Shock One also includes ten headband settings for the perfect fit, along with a noise-canceling microphone, a 3m cable and a gold-plated USB connector. An in-line control box allows easy changing of volume and microphone settings.
• Driver unit: 40mm
• Frequency Response: 20Hz~20 KHz
• Impedance: 32 ohm
• Sensitivity: 114+/-3dB
• Max. input: 100mW
• Cable length: 3m
• Connector: USB
Was £59.98 Inc. VAT
Only £53.98 inc VAT.
ORDER NOW
Energy Sistem Energy DJ 600 Professional DJ Headphones, Black @ £38.99 inc VAT
Cutting-edge design in anodized alloy with breakneck bass response and crystal clear sound, these headphones provide an exceptional listening experience. Hours of listening pleasure thanks to extra large injected foam pads and its wide flat headband. Compatible with iPod and iPhone.
• Extra Large Foam Pads
• Maximum Comfort And Lightweight
• Gold Plated 3.5mm Jack
• Crystal Clear Sound
• Deep Bass Response
• Enclosed Dynamic Circumaural Headphones
• Guarantee: 36 Months
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Logitech C210 1.3 Megapixel USB Webcam @ £13.44 inc VAT
Anyone can make a video call with a video-calling application built right into your webcam setup.
Free, fast calling
Logitech Vid™ HD is free, fast and easy for you and anyone you call. It sets up when you set up the webcam.
The real you
Your loved ones will see you in lifelike color when you talk to them, or you can take photos to share later.
It fits
The universal clip lets you attach your webcam to your notebook or LCD monitor—or sit it on a shelf or desk.
Includes Logitech Vid™ HD
Now video calling is free, fast and easy for you and anyone you want to talk to. It’s built into your webcam setup, so you can call right away.
Clear video calls
With your webcam’s VGA sensor, the people you care about will see you in lifelike color.
1.3-megapixel photos
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced)
Universal clip
It’s easy to take snapshots at up to 1.3 megapixels (software enhanced). You can attach your webcam securely to a notebook or LCD monitor, or sit it on a shelf or desk.
Free video editing software
Logitech has teamed up with MAGIX to offer MAGIX™ Photo Manager 9 and MAGIX™ Video Easy with your new Logitech webcam. And they’re free.
Built-in mic with RightSound™
It gives you clear conversations without annoying background noise.
RightLight™ technology
It automatically adjusts the image during your call, so you look your best even in dim light.
IM compatibility
Works with Skype™, Windows Live™ Messenger, Yahoo!® Messenger, AOL® Instant Messenger (AIM®) and other popular instant messaging applications.
Was £13.98 Inc. VAT
Only £13.44 inc VAT.
ORDER NOW
Creative Live! Cam Socialize 1.3 Megapixel Webcam With Built In Microphone @ £17.98 inc VAT
Make instant messaging come alive with the Live! Cam Socialize webcam and Live! Central 2 software!
The software lets you add a little spice to your conversations with dramatic voice effects and funny visual effects. Communicating and connecting with friends and family have also been made easier with a host of different features. The Live! Contacts button brings up your online contact list instantly so that you can start chatting right away while the Media Show and Desktop Share features let you share your pictures, presentation slides and videos through popular instant messaging services.
Equipped with a built-in noise-canceling microphone, engage in clearer voice chats with reduced background noise, while basking in better face-to-face interactions with the new low-profile design.
- Sensor: VGA (640 x 480) CMOS image sensor
- Video Resolution: Up to 800 x 600 pixels
- Picture Resolution: Up to 1280 x 960 pixels
- Frame Rate: Up to 30fps at 800 x 600 pixels
- Integrated microphone with noise-cancellation
- Works with native Windows ® drivers for instant Plug & Chat
- Snapshot / Live! Contacts button
- Fixed focus
- Multi-attach base
- Cable length: 1.7 meters / 5.5 feet
- Hi-Speed USB 2.0
- 1-year limited hardware warranty
System Requirements
Intel Pentium 4 2.4GHz or equivalent processor
Windows XP with SP2 / Windows Vista / Windows 7
Apple Macintosh OS X 10.5
Linux 2.6
512MB RAM
USB 2.0 Port
Was £19.99 Inc. VAT
Only £17.98 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £1.32 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £2.99 Inc. VAT
Only £1.32 inc VAT.
ORDER NOW
Swann Monitoring Kit With PNP-51 day/night Camera and 7 Inch LCD Screen @ £132.00 inc VAT
The Home and Business Monitoring Kit is a new generation of the SecuraView, one of Swannn's best selling products. It allows you to view and hear security video on a crystal clear 7 inch color LCD monitor. The monitor connects to the color camera via a 60 foot / 18 meter cable. You can operate using the remote control in the pack. Both the monitor and camera must be connected to mains power. The pack also includes 4 theft deterrent stickers and everything you need to get started. The Home and Business Monitoring Kit is perfect for anyone wanting an affordable starting point for their security needs. It's ideal for small businesses, retail stores, restaurants or home use. The unit has a discreet, small footprint with a modern and stylish finish. It's a cost effective way to see AND hear what's really happening. You will love the color video. Unlike black and white systems, you will be able to identify what color clothing people are wearing, what color hair they have, and get a truer picture of what is going on. It's easy to do-it-yourself. Mount the camera to a wall or ceiling is simple with screws included in the pack. The LCD monitor can be mounted upside down or side-ways and the video will realign itself to be the right way up using the image flip option. For discretion and to save power you can also use the auto turn-off function when the unit is not needed. The Home and Business Monitoring Kit includes a PNP-51 camera with short range night vision and a built-in microphone to allow you to hear conversations and other sounds. The Kit is also upgradeable in that you can add a second camera and then switch camera views.
- Mount camera & LCD to walls or ceilings
- LCD image flip option. Mount lcd monitor upside down or side ways & flip the image around the right way
- Auto turn on/off LCD monitor - Set time to automatically turn the montior on & off
- Add a second camera - Automatically switch camera views at 4 to 8 second intervals
Was £134.99 Inc. VAT
Only £132.00 inc VAT.
ORDER NOW
CyberPower DX600E UPS @ £59.99 inc VAT
The DX Series UPS is a cutting-edged UPS system which is ideally designed for home and small office. It can perfectly protect users’ equipment from damaging lightening and surges that cause serious data loss. This DX Series UPS includes an advanced Energy-Saving Technology that significantly improves UPS operating efficiency and reduces energy cost for users. The LED status and battery capacity indicators allow users to monitor power status and battery backup condition to manage data saving more efficiently. Its compact design also assists users to make the best advantage of interior space.
Features & Benefits:
• GreenPower UPS™ Technology : Energy-Saving UPS
• EMI, RFI, Surge and lightning spike protection
• LED status & Battery Capacity Indicators
• Auto-Shutdown software
• USB connectivity port
• 3 power outlets
• Compact design with highest power output
• Equipment Protection Policy up to 50,000 Euros
Was £65.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
CyberPower GreenPower 600VA UPS with AVR @ £58.79 inc VAT
The GreenPower Series UPS with Automatic Voltage Regulator (AVR) is the best solution for SOHO to supply a clean and stable power. The GP series UPS is compatible with many different operating systems, including Microsoft Windows 98/Me/2000/NT/XP/Vista. PowerPanel® Personal Edition management software included for USB Port shows versatility of a UPS, like power voltage, scheduled shutdown, and remaining battery capacity?remaining battery runtime?battery status ...etc. Value GP Series UPS can save upto 75% of electricity and save your electricity bill.
- Energy-Saving UPS
- Automatic Voltage Regulator (AVR)
- Auto scheduled software
- USB & Serial connectivity ports
- 3 Output Connectors
- Compact design with highest power output
- Power Management software included
- Green Power Technology
- Auto restart / Auto charge
- Save upto 75% of electicity
- Equipment Protection Policy up to 25,000 Euros
- 600VA / 360W
- Cables Included: 1 x power cable - integrated
Was £61.26 Inc. VAT
Only £58.79 inc VAT.
ORDER NOW
Energenie 30 Minute Rundown Timer @ £5.04 inc VAT
This rundown timer will switch off the mains power to your appliance after 30 minutes.
Suitable for:
• hair strighteners
• irons
• curling tongs
• electric blankets
• bedroom lamps
• bedroom TVs etc
Voltage: 220 - 250v ac 50Hz
Maximum load: 13A, 3kW
Manual reset button & indicator lamp
Timeout period: 30 minutes
Was £7.88 Inc. VAT
Only £5.04 inc VAT.
ORDER NOW
Swiftech Apogee GTZ Waterblock - 1366 & 2011 Compatible @ £58.79 inc VAT
The Apogee™ GTZ is Swiftech's new flagship water-block. While it shares the same name with its predecessors, it also leaps beyond the GT and GTX performance charts thanks to an entirely new design that pushes and refines both thermal and mechanical specifications to the limits of today's technology. Thermal design of the cooling engine combines the benefits of direct coolant impingement over the CPU area with an entirely new copper base plate design which is primarily characterized by a pin matrix composed of 225 µm (0.009") micro structures. This results in a 20% improvement in thermal resistance compared to the Apogee™ GTX. Mechanical design of the copper base plate is optimized for Intel socket 775, 2011 and 1366 and features a topographically mapped CPU contact area which results in a 75% and up to 300% improvement in TIM joint thermal resistance compared to the Apogee™ GT/GTX series. It should be noted that other types of sockets (AMD socket F, AM2, 940) may also benefit from the enhanced contact area to a lesser extent.
Was £59.99 Inc. VAT
ORDER NOW
EK Supreme HF CPU Waterblock - Full Nickel @ £68.52 inc VAT
The Ultimate CPU Waterblock
After 2 successful years of EK-Supreme CPU water block, EK has released its successor. The EK-Supreme HF - Full Nickel Block is based on same concept as EK-Supreme.The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of nickel plated electrolytic copper material. Mounting plate is made of powder coated stainless steel. The EK-Supreme HF - Full Nickel cooling engine uses fin design. The water accelerates through thin jet plate channels through 49 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Blocks main improvements are:
- better flow up to 50% higher flow compared or EK-Supreme
- better cooling performance
Enclosed in the box:
- EK-Supreme HF - Full Nickel water block
- 4 different jet plates + 1 blank
- Universal supported mounting plates:
o Intel: 775, 1366, 1156, xeon
o AMD: AM2, AM2+, AM3, 939, 754, opteron
- Universal CPU retention backplate
- Thermal grease Arctic Cooling MX-2 (2g)
Supported sockets:
Processor compatibility:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Was £69.98 Inc. VAT
Only £68.52 inc VAT.
ORDER NOW
XSPC RayStorm CPU WaterBlock (Intel) @ £47.99 inc VAT
Our best ever performing water block, with a unique new look.
- Designed for Multi Core CPU’s
- High Performance Copper Base 56x56x3mm
- CNC Cut Acetal Top
- G1/4? Threads
- 4x 3mm LED Holes
- Compatible with Most Compression Fittings
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
Supplied with mounting hardware, 775, 1156/1155, and 1366/2011 backplates,
twin blue LED, allen key, and K2 thermal paste.
Was £49.98 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
EK-FC7950 Backplate - Black @ £19.19 inc VAT
EK-FC7950 Backplate is a retention backplate made of black painted aluminum for EK-FC7950 series water block.
Backplate cover the whole lenght of graphics cards PCB, serves as an aesthetic add-on and also provides passive cooling for the backside of voltage regulation module (VRM).
This backplate is guaranteed to be compatible only with AMD reference design Radeon HD 7950 graphics card in combination with any EK-FC7950 series water block. No other water blocks are officially supported! Please check our Cooling Configurator for detailed compatibility list!
Enclosed:
- EK-FC7950 Backplate - Black
- mounting mechanism
- thermal pads
Made in Slovenia - Europe!
Was £19.99 Inc. VAT
Only £19.19 inc VAT.
ORDER NOW
EK-FC7950 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £73.79 inc VAT
Please note, This item is a PLEXI + Nickel Waterblock. The item has not been produced yet and no stock photo is available.
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7950 graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7950 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
G1/4" threaded fittings can be used on both side of the water block (on copper and plastic) and 2 plugs (EK-Plug G1/4) are enclosed!
Enclosed:
- EK-FC7950 series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
PLEASE NOTE:
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Was £74.99 Inc. VAT
Only £73.79 inc VAT.
ORDER NOW
EK-FC7970 Full Cover Waterblock - Nickel Acetal **EN Nickel Plating** @ £73.99 inc VAT
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7970 and -7950 graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7970 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB also offers a single-slot I/O bracket which frees adjacent PCI/PCIe expansion slot. The bracket is available as an optional add-on and can be purchased through EKWB webshop.
Enclosed:
- EK-FC7970 series water block
- thermal pads
Was £79.99 Inc. VAT
Only £73.99 inc VAT.
ORDER NOW
XSPC Razor 7970 GPU Waterblock @ £77.99 inc VAT
Full Cover VGA Water-Block
- CNC machined copper base
- CNC machined aluminium VRM cooler
- 1mm fins for high performance
- CNC cut stainless steel top
- Dimensions 220 x 142 x 9mm (18mm at ports)
- Prepared for crossfire with 4 G1/4? ports
- Supports ATI 7970 cards
(ATI reference design only)
Supplied with mounting kit, G1/4" plugs, thermal pads and thermal paste
Was £82.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Alphacool HF D5 TOP - Black Acetal G1/4 @ £20.78 inc VAT
The ultimate top for your Alphacool power pump offers even better performance as well as more mounting and connective possibilities for your favorite pump!
The base performance of the Alphacool TPP & VPP is already truly exceptional, but what if there is a possibility to improve even on that? This idea was also what has driven the developers which have created a product that does not only increase performance but also offers other additional advantages over the base model pump.
One of the greatest advantages are the G1/4” connection threads both at the sides and top of the pump cover. Both can be used separately or even in a combination. For the unused connection threads two knurled copper plated screw plugs are included.
The design is also a factor which was not taken lightly! The elegant black Acetal material with integrated Alphacool logo gives a clue of the potential of the German Know-how in these tops!
Mounting is done quickly and easily. With a simple twisting motion the motor is separated from the mount. After that you will find 4 separated basic components. First pull the O-ring over the polished silver front piece of the pump and then push on the largest of the 4 components. At the back, where the cable is coming out of the case, the counterpiece is pushed on. With the included mounting screws the elements can be tightly connected and you are done!
And what purpose has the last plate? It can be used for mounting of the pump in the case! Simply screw the plate to the pump’s top and the opposite side to the case or decoupling module and you are set to go!
And you will notice: This is yet another great piece of engineering from the Alphacool team!
Technical specifications:
Material: Acetal
Color: Black
Connection thread size: 4x ¼”
Dimensions mounted (L x W x H): 80 x 45 x 80mm
The installation manual of Alphacool HF D5 TOP you can find here as Download.
Extent of delivery:
1x Alphacool HF D5 TOP - Black Acetal G1/4 - (VPP655/TPP644/MCP655)
2x Copper plated screw plugs
Black mounting screws
Please note:
Delivery without pump!
Was £21.98 Inc. VAT
Only £20.78 inc VAT.
ORDER NOW
Hardware Labs Black Ice GT Stealth 120 Radiator @ £26.38 inc VAT
The GTS120 boasts of a radically redesigned Black Ice® core technology that maximizes heat transfer efficiency and maintains effectively the same compact profile of the Black Ice® Pro.
Features:
- Two-pass U-flow tank configuration.
- Custom MaxFin™ 25 micron Copper Splitter Fin Configuration utilizing 45% thinner fin material yielding up to 50% less pressure drop even with twice the fin density.
- Unique fin configuration eliminates intra-louver accumulation of dust particles for trouble free operation.
- Unprecedented Ultra-high 30 FPI (Fins Per Inch) fin density providing dramatically increased heat transfer surface area.
- Custom low-profile 19.0 x 1.2mm MaxFlow™ tubes with 15% more waterside surface area and 60% frontal area reduction for superior low air-resistance aerodynamics and lower internal flow requirements.
- Yields up to 20% more heat exchange capacity than the Black Ice® Pro in both Stealth or Performance modes.
- Achieves Black Ice® Xtreme level performance in stealth mode (low-noise/low-airflow conditions).
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Now standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Pro and most 120mm form factor radiators.
- Uses 100% Non-corrosive water-solluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Renowned Black Ice® quality.
- Patent Pending Design
Was £30.98 Inc. VAT
Only £26.38 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £59.99 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- Standard G 1/4" female threaded fittings.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Carbon Black Finish.
- Patent Pending Design.
Was £69.98 Inc. VAT
ORDER NOW
Hardware Labs Black ICE SR-1 360 Radiator @ £74.39 inc VAT
The Black Ice® SR1-360 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX360 and most 3x120mm fan form factor radiators.
Was £83.98 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
Phobya 5,25" Single Bay Reservoir Black @ £23.99 inc VAT
Phobya's first Slot-in reservoir with many technical innovations and great details: A true optical highlight! This is more than just a Plexi reservoir!
The main function of a reservoir in a water cooling loop is to offer space for expansion of the coolant, deaerate the loop and also help with initial filling. This is where the innovations from the developers at Phobya comes into play: An internal channel system helps with deaeration to ensure all air bubbles being removed from the coolant.
Even with very powerful pumps this reservoir is able to remove the air bubbles from the system. The filling of the reservoir can be done easily and quickly by removing the 3/8" screw plug after pulling the reservoir out of the drive bay. We recommend using a funnel for filling.
An even easier solution is connecting a Fillport which will allow filling without pulling the reservoir from the case.
The small details are what makes this reservoir great: Four G1/4" threads give many connection possibilities for maximum versatility.
The optical aspect of a watercooling is also very important! Especially in large enclosures there are usually too many 5.25" drive bays. With this handy reservoir they can now be used and will look even better to make the front of your system even more beautiful. A second thin Plexi plate on the actual reservoir front protects the black middle plate with the words "PHOBYA". Besides the Phobya inscription a fill level indicator is integrated to allow checking of the fill level at the front of the case. Especially with coloured coolant the fill level indicator provides a beautiful effect and sets a unique accent.
This effect can be improved even further when using the four 5mm LED holes at the rear for unique lighting effects inside of the reservoir.
The reservoir is shipped with all parts required for mounting. For mounting the reservoir can simply be pushed into the front of the tower and mounted with the black hexagonal socket screws. As usually only two of the four connection threads are used, two black nickel plated screw plugs are included.
Technical details:
Material: Acryl/Plexi (PMMMA)
Color: Transparent, black front
Dimensions (L x W x H): 175 x 149 x 44mm
Led holes: 4x 5mm
Filling opening: 1x 3/8Zoll
Connection threads: 4x 1/4Zoll
Complies with Rohs directives!
Extent of delivery:
1x Reservoir
2x Screw plugs
4x 5mm mounting screws
4x Washers
Was £24.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
1 Pack - Verbatim BD-R 6x 25GB Blu-ray Print J/C (43712) @ £3.59 inc VAT
BD-R SL 25GB 6x Printable Single Jewel Case The advent of Blu-ray technology has led to the introduction of high capacity storage discs to meet the demand cause by the rapid growth of high definition television (HDTV).
Key Features
• Hard Coat protective layer
• Extremely long archival life
• Excellent playback performance
• BD-R is for use in BD drives and recorders
• Laser Wavelength: 205nm
Blu-ray discs get their name from blue laser technology. The shorter wavelength of the laser is the reason it is blue in colour. The blue laser has a wavelength of 405nm compared with the wavelength of 650nm for DVD which utilises red laser technology. The benefit of having a blue laser with a shorter wavelength means it is possible to write smaller data pits and therefore vastly increase the amount of data on the disc.
Blu-ray discs offere 3 to 5 times the storage capacity of a standard recordable DVD disc, enabling the recording, rewriting and playback of high definition video (HD).
Was £3.74 Inc. VAT
Only £3.59 inc VAT.
ORDER NOW
50 Pack - Kodak DVD-R 16x Shrink Pack @ £8.40 inc VAT
DVD-R - 4.7GB - 16x Write Speed - Shrink Pack - 50 Pack
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
25 Pack - TDK CDR-80 52x 25pc Cakebox (T18767) @ £4.79 inc VAT
Developed for ultimate performance, and manufactured to the most exacting standards, TDK CD-R media is the ideal digital storage solution. CD-R disks are write once, meaning a CD-R can be fully recorded one time, but can't be erased or rerecorded.
Key Features
• Write-Once CDR
• Native Capacity 700MB
• Write Speed 52x
• Package Type Spindle
• Disc Surface Silver
Was £4.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Netgear WNDR3400 Wireless-N N600 Wireless Dual Band Cable Router @ £84.19 inc VAT
Netgear WNDR3400 Rangemax Dual Band Wireless-N Router
The NETGEAR N600 Wireless Dual Band Router offers the high-performance wireless Internet access needed for demanding applications, such as streaming multimedia and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the greatest range.
Features
Dual band - Offers twice the bandwidth with better connection and less interference
Faster multimedia streaming - Provides Wireless-N speed and dual band performance for streaming video, multiplayer online gaming and simultaneous downloads
Shared storage - ReadySHARE™ provides fast and easy shared access to an external USB storage device Jitter-free video and gaming - Video Quality of Service (QoS) for reliable Internet connections
Live Parental Controls - keeps your Internet experience safe
Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
Guest network access - Provides separate security and access restrictions for guests using the network
Broadband usage meter - ensures daily, weekly and monthly measurement of Internet traffic with customized alerts
Easy setup - Smart Wizard® CD with graphical installation guide
Secured connection - Push ‘N’ Connect with Wi-Fi Protected Setup® (WPS)1 ensure a quick and secure network connection
NETGEAR Green features - Power and Wi-Fi on/off buttons, Energy Star-compliant power adapter and 80% recycled packaging
System Requirements
Broadband (cable, DSL) Internet service and modem with Ethernet connection
2.4 or 5.0 GHz 802.11a/b/g/n specification wireless adapter or an Ethernet adapter and cable for each computer
Microsoft® Windows® 7, Vista®, XP, 2000, Mac OS®, UNIX®, or Linux®
Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari 1.4 or higher
Standards
IEEE® 802.11 b/g/n 2.4 GHz
IEEE 802.11 a/n 5.0 GHz
Five (5) 10/100 (1 WAN and 4 LAN) Ethernet ports with auto-sensing technology
Performance
480 MHz powerful MIPS 32-bit processor
Memory: 8 MB flash and 64 MB RAM
Five (5) (1 WAN, 4 LAN) Fast Ethernet ports
Advanced Quality of Service (QoS)
Supports Wireless Multimedia (WMM) based QoS
Was £94.99 Inc. VAT
Only £84.19 inc VAT.
ORDER NOW
Netgear WNDR4000 Wireless-N N750 Wireless Dual Band Cable Router @ £118.79 inc VAT
The NETGEAR N750 Wireless Dual Band Gigabit Router offers high performance wireless speeds of up to 450Mbps (5GHz only) needed for demanding applications, such as large file transfers, streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the highest range, while Gigabit offers ultra-fast wired connections.
WAN Gigabit Ethernet port for cable/fiber combined with a wireless router create the Ultimate Integrated Home solution
Concurrent Dual band - Eusuring top speeds and the greatest range while minimizing interference
Faster multimedia streaming - Provides Wireless-N speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications
Shared storage - Two ports for ReadySHARE® USB Storage Access provides fast and easy shared access to an external USB storage device
Live Parental Controls - Keeps your Internet experience safe
Secured connection - Push ‘N’ Connect ensures a quick and secure network connection
Broadband usage meter - Monitors Internet traffic and sends customized reports to help keep costs under control
Easy installation - Connect to PC and open your browser to install
Compatibility - Compatible with all major ADSL Internet service providers (ISPs)
Was £139.98 Inc. VAT
Only £118.79 inc VAT.
ORDER NOW
OP
8 Sep 2003
150 yds from OcUK
TP-Link 200Mbps AV200 Mini Powerline Adapter (TL-PA211) @ £21.60 inc VAT
TP-LINK's TL-PA211 powerline adapter takes advantage of your home's existing electrical wires to transfer data while simultaneously transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and instantly establish a networking infrastructure. With high-speed data transfer rates of up to 200Mbps, users can enjoy HD video streaming, online gaming, VoIP or any other bandwidth intensive tasks for work or play.
With its new ultra-compact housing design, TP-LINK's TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it nearly blends completely in front of any power outlet.
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices - from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
The TL-PA211, a new-generation Powerline Adapter, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 65%.
- HomePlug AV standard compliant, high-speed data transfer rate of up to 200Mbps, enough for HD video streaming
- Super Small Design with a new exterior, blends in completely in front of any power outlet
- No new wires, uses existing electrical wires
- Up to 300 meter range over the household power circuit for better performance through walls or across floors
- Easy Plug and Play operation, No configuration required
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%*
- Establish a 128-bit AES encryption to secure powerline communications simply by pressing the Pair button on the adapter
- Built-in QoS assures the quality of bandwidth sensitive applications such as voice, video and online games
- Supports IGMP managed multicast IP transmission, optimizes IPTV streaming
- A wide range of plug type including EU, UK, AU and US ensures that it can be used nearly all over the world
Was £21.98 Inc. VAT
Only £21.60 inc VAT.
ORDER NOW
Corsair Flash Voyager 8GB USB3.0 Flash Drive
(CMFVY3S-8GB) @ £10.99 inc VAT
Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
Fast – Access videos, pictures and large files up to 4x faster read speeds than traditional USB 2.0 drives
Durable – Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
Shock Proof – Solid state storage makes Flash Voyager drives virtual shock proof.
Convenient – Just plug it in and go! Works with Windows, Mac OS X and even Linux without drivers.
Compatible – Designed for USB 3.0, backward compatible with USB 2.0
Backed by Corsair – A respected name with a passion for quality and customer service.
- Fast USB 3.0 connectivity;
- Durable rubber housing;
- Water resistant;
- Shock proof;
- 5 Year Manufacturer Warranty;
Was £14.99 Inc. VAT
Only £10.99 inc VAT.
ORDER NOW
Kingston DataTraveler Generation 3 4GB USB2.0 Flash Drive (DTIG3/4GB) @ £2.99 inc VAT
The reliable DataTraveler Generation 3 is ideal for your important documents, music, video clips and favourite photos that can be stored and retrieved in a flash. Available in fun colours by capacity, it’s a perfect fit for the office, home, school and wherever you travel. A well-built cap protects the USB plug and your data.
- Capacity: 4GB
- Speed - data transfer rates of up to 10MB/s read and 5MB/s write
- Dimensions - 65.68mm x 10.66mm x 22.37mm
- Simple - just plug into a USB port
- Practical - cap protects the USB plug
- 5-Year warranty
Was £4.99 Inc. VAT
Only £2.99 inc VAT.
ORDER NOW
OcUK Value 4GB USB Drive Black @ £3.95 inc VAT
OcUK Value PinStripe 4GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
- Push and pull sliding feature
- Enhanced for Windows ReadyBoost
- Includes EasyLock Password Protection Software Trial
- Compatible with Windows 2000, XP, Vista & Windows 7
- Compatible with Mac OS 9 or higher & Linux 2.4.0 or higher
With ports in almost every computer and popping up in cars, DVD and Multimedia players, TV's, Photo Frames and many more, USB drives are now being considered an essential accessory.
Was £4.99 Inc. VAT
Only £3.95 inc VAT.
ORDER NOW
OcUK Value 8GB USB Drive Black @ £5.99 inc VAT
OcUK Value PinStripe 8GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £8.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Corsair Flash Survivor® 16GB USB3.0 Flash Drive (CMFSV3-16GB) @ £21.98 inc VAT
Your files are important — that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Capacity: 16GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Was £27.95 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Corsair Flash Voyager Mini 16GB USB2.0 Flash Drive (CMFUSBMINI-16GB) @ £15.98 inc VAT
The ultra portable Flash Voyager Mini packs a lot of features in its small package. It utilizes a cap-less retractable connector plug which easily opens with the flick of the thumb. The ergonomic rubberized housing makes it easy to connect and disconnect from any computer. Utilizing an all-rubber housing, the Voyager Mini is water-resistant and shock proof, allowing users to carry their value data and applications without compromise. The Corsair Flash Voyager Mini is the perfect flash drive for users with busy and active lifestyles. Utilizing the latest Chip-on-Board technology the Flash Voyager Mini is the perfect synergy of size, looks and function.
- Capacity: 16GB
- Durable
- Shock Proof
- Retractable connector tip
- Plug-n-Play compatibility via USB 1.1 or 2.0 port
- 10 Year Limited Warranty
Was £24.98 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Corsair Flash Voyager 16GB USB3.0 Flash Drive (CMFVY3S-16GB) @ £17.99 inc VAT
"Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
- Water resistant;
- Shock proof;
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Corsair Flash Voyager 32GB USB3.0 Flash Drive (CMFVY3S-32GB) @ £24.98 inc VAT
- Water resistant;
- Shock proof;
Was £29.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Corsair Flash Voyager GT 16GB USB3.0 Flash Drive (CMFVYGT3-16GB) @ £17.99 inc VAT
Premium performance, high-capacity USB 3.0 flash drives with renowned Flash Voyager durability and high-speed file transfers even on USB 2.0 systems. The unique all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
The Flash Voyager GT USB 3.0 really takes advantage of the performance of USB 3.0, with up to 8x the speed of a typical USB 2.0 flash drive. But even when used on a USB 2.0 port it’s one of the fastest drives on the market. The unique all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data. Just plug it in and it works, with Windows, Mac OS X and even Linux. The Flash Voyager GT USB 3.0 is backed by Corsair, a respected name with a passion for quality and customer service.
- Unformatted Capacity: 16GB;
- Max Read (USB 3.0): 135 MB/sec;
- Max Write (USB 3.0): 41 MB/sec;
- Interface Type: USB 3.0;
- Shock: 40G;
- Warranty: 5 Years Manufacturers Warranty;
Was £21.95 Inc. VAT
ORDER NOW
Corsair Flash Voyager GT 32GB USB3.0 Flash Drive
- CMFVYGT3-32GB @ £35.99 inc VAT
- Unformatted Capacity: 32GB;
- Shock: 40G;
Was £43.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
OcUK Value 16GB USB2.0 Drive Black @ £9.98 inc VAT
OcUK Value PinStripe 16GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £16.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
OcUK Value 32GB USB2.0 Drive Black @ £17.99 inc VAT
OcUK Value PinStripe 32GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £26.99 Inc. VAT
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) @ £58.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £61.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - OEM (0F10383) @ £74.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Warranty: 2 Years
Was £79.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) @ £77.99 inc VAT
The new Barracuda ST1000DM001 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST1000DM001 drive is built on a full-speed, 7200RPM platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST1000DM001 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST1000DM001 drive offers.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 2 Years
Was £79.99 Inc. VAT
ORDER NOW
Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM (WD20EARX) @ £99.95 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Spin Speed: IntelliPower (5900rpm)
- Warranty: 2 Years
Was £107.99 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £59.99 inc VAT
nonl2brAs the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
<br><br>
- Capacity: 60GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 525MB/sec<br>
- Maximum Write: 475MB/sec<br>
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- Warranty: 3 Years<br>
<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/rF5PdfFGomw" frameborder="0" allowfullscreen></iframe>
Was £63.98 Inc. VAT
ORDER NOW
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £99.95 inc VAT
<br><br>
- Capacity: 120GB<br>
- Maximum Write: 500MB/sec<br>
<br>
<br>
Was £103.99 Inc. VAT
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £119.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br>
<br>
- Maximum Read: 550MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- 2.5" to 3.5" SSD adaptor included<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £239.99 inc VAT
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Capacity: 240GB<br>
- Maximum Write: 520MB/sec<br>
- Sustained Write: 520MB/sec<br>
<br>
Was £249.98 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
OCZ Vertex 4 128GB 2.5" SATA-3 Solid State Hard Drive (VTX4-25SAT3-128G) @ £137.99 inc VAT
nonl2brAs the fourth generation of the legendary Vertex line, the Vertex 4 Series pushes storage performance to the max and redefines the modern day computing experience. Vertex 4 SSDs are innovatively engineered to deliver industry-leading file transfer rates and superior system responsiveness, all while providing a more durable, reliable, and energy efficient storage solution compared to traditional hard drives. Designed to take full advantage of the SATA III interface, the Vertex 4 unleashes ultimate productivity, gaming, and multimedia applications.<br>
<br>
Industry’s Highest I/O Performance Up to 120K IOPS<br>
Incredible performance in workstation and heavy-duty environments with multiple data threads<br>
<br>
No Compression-Related Performance Limitations <br>
Better performance with “real world” data streams of varying “compressibility” as well as fully incompressible data such as videos and multimedia files, encrypted data, archive files such as .ZIP files and software. <br>
<br>
Indilinx Infused™ Everest 2 Platform<br>
Leading edge dual-ARM controller architecture enables faster performance like nothing else you’ve experienced. <br>
<br>
Industry-Low Latency and Boot Ups<br>
Boot up in as little as 9 seconds, and experience latencies of 0.02ms enable superior responsiveness and data access.<br>
<br>
Ndurance 2.0 Technology<br>
Sophisticated advanced suite of NAND Flash management increases durability and reliability to expand the NAND’s lifespan. <br>
<br>
Industry-Leading 5 Year Warranty <br>
Backed by OCZ’s renowned service for ultimate peace of mind. <br>
<br>
- Capacity: 128GB<br>
- Up to 535 MB/s Sequential Reads<br>
- Up to 200 MB/s Sequential Writes<br>
- Up to 90,000 Random Read IOPS<br>
- Up to 85,000 Random Write IOPS<br>
- Up to 120,000 Maximum IOPS<br>
- Available in 128GB to 512GB Capacities<br>
- Access Latency as Low as 0.02ms<br>
- Strong Performance at Lower Queue Depths <br>
- Indilinx Everest 2<br>
- DRAM Cache: Up to 1GB<br>
- 5 Year Warranty<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/0LLzUSF6ZLY" frameborder="0" allowfullscreen></iframe>
Was £149.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
OCZ Vertex 4 256GB 2.5" SATA-3 Solid State Hard Drive (VTX4-25SAT3-256G) @ £269.99 inc VAT
<br>
<br>
<br>
<br>
<br>
<br>
<br>
- Capacity: 256GB<br>
- Up to 380 MB/s Sequential Writes<br>
<br>
Was £284.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Asus Xonar D2 7.1 PCI Sound Card @ £83.99 inc VAT
ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- Unprecedented SNR Up to 118db reaching the limit of PC sound clarity
- High-definition audio processing at 192KHz/24Bit for all Input and outputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theatre System
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £83.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £89.99 Inc. VAT
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £22.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £25.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £18.98 inc VAT
**Supplied with Driver disk, Manual, Low profile PCI bracket and Xonar DG card - All thats missing is the box!**
Was £22.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Asus Xonar DX 7.1 PCI-Express Sound Card @ £53.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscape has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar DX driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar DX audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 116dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar DX is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- Unprecedented SSNR NR Up to 116db reaching the limit of PC audio sound quality clarity
- Legally backup your digital music into non-protected MP3/WMA files with even better quality and Dolby Headphone and Virtual Speaker effects
- Low Profile Bracket Included
- Vista Ready
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £175.99 inc VAT
nonl2br
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.<br>
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
<br>
- 232 Watts RMS of continuous power delivery through six Class D amplifiers <br>
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure <br>
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters <br>
- Clean, high-fidelity audio reproduction with excellent stereo imaging <br>
- Programmable digital signal processor for advanced dynamic audio processing <br>
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface<br>
<br>
Specification:<br>
- Frequency response of 35Hz – 20kHz +- 3dB<br>
- 232 Watts of total power (measured via FTC “RMS” method)<br>
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction<br>
- Subwoofer: 8” subwoofer driver with durable rubber surround<br>
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)<br>
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input<br>
- Satellites: Bi-amplified, two-way design with detachable audio cables<br>
- Satellites: 3” midrange drivers<br>
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters<br>
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging<br>
- I/O, Controls, and Programming: PC input on subwoofer<br>
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)<br>
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing<br>
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface<br>
- I/O, Controls, and Programming: Digital signal processor with active crossover capability<br>
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience<br>
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music<br>
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide<br>
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)<br>
- Weight: 30.75 lb (13.9 kg)<br>
<br>
<CENTER><iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/VOo686QhINc" frameborder="0" allowfullscreen></iframe></CENTER>
<br>
Was £181.99 Inc. VAT
Only £175.99 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Aqua Blue 20cm @ £13.99 inc VAT
Part of the BitFenix Alchemy Premium Modding Series, Alchemy LED Strips are the ideal choice when modding inspiration strikes. These precision manufactured LED Strips come with BitFenix TriBright™ LED Technology for the absolute brightest LED strips available. Alchemy LED Strips come in both chainable Connect and waterproof Aqua, and offer a multitude of lengths and colors, enabling you to bring your modding vision to light.
When only the brightest will do, BitFenix TriBright™ LED Technology gives you the industry’s brightest LED strips. TriBright uses independent ICs to power each LED bulb for maximum brightness.
Alchemy LED Strips are made using a precision SMT manufacturing process, which means the highest quality, enhanced current conduction, and prolonged life.
Have a special idea that needs an extra-long length of LED strips? No problem. With Alchemy Connect LED Strips, you can connect as many strips together as you need with the only limitation being your power supply's current.
BitFenix Alchemy LED Strips are backed with high-grade adhesive from 3M™, which makes sure that your LED strips will remain where you left them, even when your computer is being moved around.
- Colour: Blue
- Length: 20cm
- LEDs: 6
Was £16.99 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Aqua Blue 30cm @ £18.98 inc VAT
- Colour: Blue
- Length: 30cm
- LEDs: 9
Was £20.95 Inc. VAT
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Aqua White 50cm @ £25.99 inc VAT
- Colour: White
- Length: 50cm
- LEDs: 15
Was £29.99 Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Connect White 12cm @ £7.99 inc VAT
- Colour: White
- Length: 12cm
- LEDs: 6
Was £9.29 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Aqua Red 30cm @ £18.98 inc VAT
- Colour: Red
- Length: 30cm
- LEDs: 9
Was £20.95 Inc. VAT
ORDER NOW
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3 @ £37.98 inc VAT
nonl2brVenom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.<br>
<br>
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.<br>
<br>
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.<br>
<br>
- Dual 120mm PWM fans in killer viper yellow<br>
- Six high capacity 6mm heatpipes with direct CPU contact<br>
- Award winning S-FLOW fan blades provide 30% more airflow<br>
- Rubber fan mounts for easy install and quiet performance<br>
- Fan Dimensions: 120 x 120 x 25mm<br>
- Fan Speed: 600 - 1200 RPM<br>
- Max Airflow: 83.63 CFM<br>
- Noise Level: 6.9 - 28.9dBA<br>
- Cooler dimensions: 131 (W) x 129.5 (D) x 163.5 (H) mm <br>
<br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/Rq3OJ5Jss_w" frameborder="0" allowfullscreen></iframe>
Was £44.99 Inc. VAT
Only £37.98 inc VAT.
ORDER NOW
Akasa AK-CC4007EP01 Nero 3 CPU Cooler (Socket LGA775/1155/1156/1366/2011/AMD AM2/AM2+/AM3/FM1) @ £21.98 inc VAT
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminium profiled fins ensure optimum heat dissipation. A piano black 120mm PWM fan is mounted using anti-vibration siliconized rubber pins giving whisper quiet cooling.
The product design has been refined to ensure ultra quiet and exceptional cooling for CPU’s up to 150W TDP (Thermal Design Power). It is compatible with the new forthcoming Intel LGA 2011 processors. Akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1155, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
- Four high capacity 6mm heatpipes with direct CPU contact
- Piano black 12cm fan with PWM
- Siliconized rubber fan mounts for enhance ultra quiet performance
- Cooler dimensions: 120 (W) x 86.7 (D) x 160 (H) mm
- Heatsink material: High grade aluminium fins, copper heatpipes
- Heatpipe: 6mm x 4
- Weight: 609g
- Installation: Push pins (Intel LGA775 / 1155 / 1156 / 1366)
- Screws (Intel LGA2011)
- Cam-lever clip (AMD)
- Fan dimension: 120 x 120 x 25mm
- Fan speed: 500-1500 RPM (PWM controlled)
- Max airflow: 50.54 CFM
- Max air pressure: 1.32 mm H2O
- Noise level: 24.6 dB(A)
- Voltage rating: DC 12V
- Bearing type: Sleeve
- Fan life expectancy: 30,000 hours
- Fan connector: 4pin PWM
Was £23.99 Inc. VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Red(Socket LGA 2011/1155/1156/1366/775/AMD AM2/2+/AM3) @ £62.99 inc VAT
nonl2br Phanteks PH-TC14_PE twin tower thermal radiator design uses the latest aerospace technology. By using P.A.T.S to increase cooling performance and C.P.S.C Technology to enhance thermal conductivity, heat will easily dissipate, creating an opportunity for greater overclocking. Combined with Dual Phanteks PH-F140 Premium 140mm Fans, easy-to-install SoliSku mounting kit and PH-NDC thermal compound.
<br/><br/>
With unique colours, the Phanteks PH-TC14 is setting the new standard for today’s CPU coolers.<br><br/>
<br/>
<b>TECHNIAL INFORMATION</b><br/><br/>
- Intel Socket LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3 (stock backplate required)<br/>
- Fan Size: 140x140x25 , Dual Fans included.<br>
- Full PWM Adapter included<br>
- Fan Compatibility: 140x140x25mm x 3 pcs, (120 x 120 x25mm x 3 pcs). (Third fan clips and accessory included).<br/>
- Bearing Type: UFB bearing (Updraft Floating Balance bearing)<br>
- Blade Geometry: 9 red coloured Blades with MVB (Maelström Vortex Booster) Design<br>
- RPM: 1200 RPM ± 10% (with PWM: 700-1200 RPM)<br>
- RPM with Q.S.A: 900 RPM ± 10%<br>
- Max Air Flow: 78.1 CFM (45.1CFM - 78.1 CFM)<br>
- Max Air Pressure: 1.21 (0.45 mm H2O – 1.21 mm H2O)<br>
- Acoustical Noise: 19 dBA<br>
<br/><br/>
<img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/KitGuru_MUST-HAVE-150x150.png" alt="KitGuru Must Have Award" border="0" />
<IMG SRC="http://img256.imageshack.us/img256/6861/awardsjq.jpg" height="150"/>
Was £66.98 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155/1156//1366/2011) @ £67.98 inc VAT
Intel teamed up with no other than Asetek to offer the Intel RTS2011LC self contained water cooler kit. Asetek have been making these type of kits for a while and was behind the Corsair H50 and H70 as well as the Antec Kuhler 620 and 920.
- Socket LGA1155/LGA1156//LGA1366/LGA2011
- Fan Speed: 800-2200 RPM (4 wire PWM)
- Fan Dimensions: 120 mm x 120 mm x 25 mm
- Fan Airflow: 74CFM
- Unit Noise Level: 21dBA@800 RPM / 35dBA @ 2200 RPM
- Radiator Dimensions: 150mm x 118mm x 37mm
- Pump Z-Height: 33mm
- Total Thermal Solution Weight: 820 grams
- Cooling Liquid: Propylene Glycol
- Thermal Interface Material: TC-1996
Was £72.98 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Anidees AI-6BW Midi-Tower Windowed Case - Black @ £104.99 inc VAT
nonl2br
<p>The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior and with a brushed aluminum centre. In between lie, a set of stealthy, and concealed air vents, which should ensure good cooling.</p>
<p>This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.</p>
<p>Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.</p>
<p>Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.</p>
<img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/KitGuru_WORTH-BUYING1-150x150.png" alt="KitGuru Award" border="0" />
<br/><br/>
<p>
<ul>
<li> Windowed Edition</li>
<li> Dimensions: 207 x 509 x 527 mm (W x H x D)</li>
<li>Material: steel, aluminum<br />
</li>
<li>Weight: 11 kg<br />
</li>
<li>Color: Black<br />
</li>
<li>Form Factor: ATX, Micro ATX, Mini-ITX</li>
<li> Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)<br />
</li>
<li>Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)<br />
</li>
<li>Top Cooling: 2x 140 / 120 mm (lid, optional)<br />
</li>
<li>Filters: Front &amp; Back<br />
</li>
<li>Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)<br />
</li>
<li>Power Supply: Standard ATX 1x (optional)<br />
</li>
<li>Expansion Slots: 8 (without tools)<br />
</li>
<li>I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out</li>
<li> Maximum graphics card length: 428 mm<br />
</li>
<li>Features: Elements made of brushed aluminum<br />
</li>
<li>Cable Management<br />
</li>
<li>HDD and power supply decoupling<br />
</li>
<li>Removable hard disk cages</li>
</ul>
</p>
Was £114.98 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £2.99 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £3.98 Inc. VAT
Only £2.99 inc VAT.
ORDER NOW
Akasa AK-191-SM Smoke Ultra Quiet 120mm Fan - 3 pin @ £3.98 inc VAT
Near silent 12 cm fan with distinctive Smokey coloured rotor blades and crystal clear frame. Designed with low air impedance blades, providing the ultra quiet acoustic experience.
- Dim: 120 x 120 x 25mm
- Rated speed: 1400 RPM
- Sound: 18.0 dB(A)
- Air flow: 49.74 CFM
- Bearing: Sleeve Bearing
- Life expentancy: 30,000/ hrs
Was £5.99 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM @ £7.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
PWM is a widely available feature on all current Intel and AMD platform based motherboards. It is more accurate than voltage regulation, energy saving and a fully automatic way of controlling the fan speed. PWM provides ultra quiet acoustics during normal PC use and high performance cooling under high system load. The Optional Akasa AK-CB002 cable adapter can provide the system with two additional PWM connectors if needed.
- Super silent APACHE fans in camouflage colours
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £9.98 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin @ £6.95 inc VAT
For performance and quiet. The distinctive amber colour rotor blades are designed with low air impedance which gives the ultra quiet acoustic experience. Twin ball bearing gives consistent performance and long life. 8, 9.2 and 12cm case fans with style.
- Sound: 18.0 dB(A)
- Air flow: 44.8 CFM
- Bearing: Twin ball bearing
- Life expentancy: 80,000/ hrs
!!<<img src="green.gif">>!!
Was £7.99 Inc. VAT
Only £6.95 inc VAT.
ORDER NOW
Lian Li PC-A05FNB Aluminium Midi Tower Case - Black @ £73.98 inc VAT
With its mid-tower form factor, the PC-A05FN features a 120mm intake fan - positioned at the top of the rear panel - and a 120mm exhaust fan, which finds itself located on the front panel, in front of the HDD bay. The PSU bay is also located at the front of the chassis, and for additional cooling, there's accommodation for a 140mm fan along the top panel, and venting too. As usual, Lian Li also includes two rubber-lined holes on the rear panel, allowing for flexibility with the installation of liquid cooling solutions.
The PC-A05FN provides three 3.5in and two 2.5in bays internally, plus a single 3.5in and two external 5.25in bays. Graphics cards up to 280mm in length are supported.
- Dimensions: (W) 210mm x (H) 385mm x (D) 500mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): 2
- 3.5" drive bay (External): 1
- HDD bay: 3.5” HDD x 3 / 2.5” HDD x 2
- Expansion Slots: 8
- Motherboard: ATX / Micro-ATX / Mini-ITX
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): 140mm Fan Hole x 1 ( Fan not included )
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Video Card Size: 280mm
Was £76.99 Inc. VAT
Only £73.98 inc VAT.
ORDER NOW
Akasa AK-274CR-4RDS 120mm Red LED Fan @ £4.99 inc VAT
This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The Red Hot look is achieved by four hi-bright red LED complemented with a crystal red frame and blades.
- Application PC Case fan
- Frame dimension 120 x 120 x 25mm
- Fan speed 1200 RPM
- Fan airflow 38.4 CFM
- Fan air pressure 1.17 mm H20
- Fan life expectancy 20000/hrs 25ºC
- Bearing type Sleeve Bearing
- Connector 3-pin with RPM sensor wire
- Voltage rating 12V
- Current rating 0.15 A
- Noise level 17.5 dB(A)
- Product code AK-274CR-4RDS
Was £9.98 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
BitFenix Spectre LED WHITE 120mm Fan @ £5.59 inc VAT
Introducing the Spectre™ LED Fan Series from BitFenix. Engineered for both silent operation and maximum airflow, Spectre will keep your entire system well ventilated without making it sound like an airplane hangar. Spectre LED Fans are designed with sickle fan blades, which enhance airflow without producing excess noise. Spectre is also the first LED fan series on the market that supports on-the-fly LED light switching when used together with the BitFenix Hydra Fan Controller or BitFenix Survivor Chassis, allowing you to turn the lights on and off with a press of a button. Don't have either of those? No problem. Spectre can also be used as a regular LED fan with jumper-selectable on/off.
Powerful yet whisper-quiet - The Spectre Fan Series.
- Dimensions (mm): 120 x 120 x 25
- Current (A): 0.16±10%
- Speed (RPM): 1000±10%
- Air Flow (CFM): 43.5±10%
- Noise (dB-A): <20
- Air Pressure (mmH2O): 0.62
Was £6.49 Inc. VAT
Only £5.59 inc VAT.
ORDER NOW
BitFenix Spectre LED ORANGE 120mm Fan @ £5.59 inc VAT
- Noise (dB-A): <20
Was £6.49 Inc. VAT
Only £5.59 inc VAT.
ORDER NOW
BitFenix Spectre PRO 120mm White LED - Black @ £9.95 inc VAT
Following the success of our Spectre™ LED Fan Series, Spectre Pro™ LED ups the ante with an all-new design and enhanced performance. The high pressure and CFM design produces wicked cooling and is also perfect for watercooling setups. Its dual frame construction not only looks great, but also helps to dampen vibrations that cause unnecessary noise. Reinforced fan blades prevent warping at high RPM levels, while focused airflow ensures cool air can reach all of your installed components. With FDB technology for low noise and long life, multiple color options, and on-the-fly light switching, Spectre Pro LED is the new gold standard in performance case fans.
Harness the fury with the Spectre Pro LED Fan Series.
- Dimensions (mm): 120x120x25mm
- Current (A): 0.18A ±10%
- Speed (RPM): 1200 RPM ±10%
- Air Flow (CFM): 56.22 CFM ±10%
- Air Pressure (mmH2O): 1.24 mmH2O
- Noise (dB-A): 18.9 dB(A)
- Colour: White
Was £11.99 Inc. VAT
Only £9.95 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £13.99 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
- Manufacturered in Japan
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Was £15.98 Inc. VAT
ORDER NOW
Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin @ £12.49 inc VAT
- Model-No. D1225C12B4AP-14
- Only 21.0 dB(A) at 1450 RPM
- Weight 200 g
- Air volume at full speed (12V), CFM ±10% 50.0
- Noise level at full speed (12V), dB(A) 21.0
- Fan speed at full speed (12V), RPM ±10% 1450
Was £13.99 Inc. VAT
Only £12.49 inc VAT.
ORDER NOW
NZXT Tempest 410 Midi Tower - Black @ £55.98 inc VAT
An aggressive cooling solution forged for your rig, the Tempest 410 Midtower completes your fine-tuned machine by taking advantage of the airflow required for the enthusiast’s overclocking needs. The Tempest legacy expands its maximized ventilation through the extra-large honeycomb mesh design, dual radiator support, and dual touch powered front fans. If you are looking for a new cooling edge for your gameplay, Tempest 410 will bring you the results of epic win.
- Large honeycomb steel mesh design for optimal airflow
- Dual radiator support for all-in-one liquid cooling solutions
- Latest Audio, USB 2.0, and USB 3.0 internal support
- Top storage compartment and cable routing for convenience
- Innovative dual 120mm side fan slot or adjustable single fan slot to target hot spots in the case
- Dual touch powered 120mm front fans equipped with easily removable filters for easy maintenance
- Dimensions: (W x H x D) 215 x 481 X 496mm
- VGA Clearance Maximum: 315mm w/o HDD, 290mm w/ bracket, 250mm w/ HDD installed
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm (1x included)
- Side Cooling: 2 X 120mm
- Rear Cooling: 1 X 120mm @ 1200rpm (1x included)
- Top Cooling: 2 X 120/140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 External 5.25" Drive Bays / 8 Internal 3.5"/2.5" Slots
- Screwless Rail Design
- Expansion Slots: 7
- Motherboard Support: ATX, MICRO-ATX, MINI ATX, FLEX ATX, MINI ITX
Was £59.99 Inc. VAT
Only £55.98 inc VAT.
ORDER NOW
Akasa Venom 750w Modular '80 Plus' Power Supply @ £69.98 inc VAT
AKASA Venom Power 750w modular PSU comes with 80% high efficiency and features a 135mm quiet fan.
- Form factor: ATX 12V 2.3
- Dimensions: 150 x 158 x 86mm (W x L x H )
- Typical efficiency: Over 80%
- Power Factor Correction: Active PFC
- Fan: 135 x 135 x 25mm, thermal control
- Motherboard connector: 1 (20+4pin)
- ATX12V connectors: 1 (4+4pin)
- PCIe 6+2pin connectors: 2
- SATA connectors: 6
- Molex 4pin connectors: 6
- FDD 4pin connectors: 2
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Antec High Current Gamer 750W Quad Rail '80 Plus Bronze' Power Supply @ £92.99 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-750 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-750 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-750 is the perfect PSU for you.
- 750 watts of Continuous Power
- NVIDIA&® SLI®-Ready certified, ATI CrossFire™ certified
- 80 PLUS® Bronze certified - up to 88% efficienct
- Quad High Current +12V rails with high maximum load for better graphics card compatibility
- Quiet 135mm double ball bearing cooling fan with low start voltage
- Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
- All Japanese brand capacitors for reliability
- ATX12V version 2.3 and EPS version 2.91 compliant
- Gold-plated High Current terminals for optimal conductivity
- Universal Input - works on any 100V - 240V grid
- Active PFC with PF: 0.99 - less harmonic pollution, greater efficiency
- Full suite of industrial grade protection:
- Over current protection (OCP)
- Over voltage protection (OVP)
- Short circuit protection (SCP)
- Over power protection (OPP)
- Over temperature protection (OTP)
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TUV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- AQ5 Antec Quality 5-year limited warranty on parts and labour
Was £99.98 Inc. VAT
Only £92.99 inc VAT.
ORDER NOW
OcUK Crusade 650W Dual-Rail High Efficiency '80 Plus' Power Supply @ £42.98 inc VAT
This 650W PSU is designed for entry level systems that require a lot of power. With 2 dedicated 12v rails this Power Supply ensures that power can be perfectly spread throughout your systems without any overloading while the massive 120mm silent fan helps keep the system cool.
- High Efficiency
- Auto Switch
- Multi-GPU support: independent double +12V rails designed specially for dual graphic cards
- Active PFC: enhances utilization of energy
- Ventilation: 1 x 12cm fan
- Full range: AC full range input
- Fan Speed Control
- Energy Star
- Short Circuit Protection
- Over Voltage Protection
- 1 x 20+4 motherboard connector
- 1 x 4pin CPU connector
- 4 x SATA connectors
- 4 x Molex connectors
- 2 x 6Pin PCIe connectors
- 1 x Floppy drive connector
Was £49.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
OcUK Battle 650W Dual Rail High Efficiency Modular '80 Plus' Power Supply @ £46.98 inc VAT
This 650W PSU is designed for entry level systems that require a lot of power. Split 12v rails ensure that power can be perfectly spread throughout your systems without any overloading while the massive 120mm silent fan helps keep the system cool.
The clever cable management system means you only need to add the power cables that your system actually needs, allowing for smarter cable routing for a neat and tidy case. If you add a new hard drive for example, just simply plug an additional power cable into the back of the PSU.
- High Efficiency PSU, with 80+ Certification
- nVidia SLi and ATi Crossfire Ready
- Dual Rail Design
- Multi-core CPU support
- Advanced Thermal & Accoustic Design
- ATX 12V V2.2 Design Guide Compatible
- Low noise cooling fan system.
- ATX 20+4P, 12V 4+4P, 6+2P SLi, 4P Molex, SATA and Floppy Connectors
- EZ Connector System
- Various Cable Length
- New generation design
- 1 x 20+4pin Motherboard connetor
- 1 x 4+4pin CPU 12v connector
- 2 x 6+2 pin PCIe connectors
- 1 x Floppy Drive connector
Was £50.99 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Razer DeathAdder Respawn 3500 DPI Xtreme Precision Gaming Mouse - Retail @ £44.99 inc VAT
The Razer DeathAdder is the weapon of choice for gamers seeking a combination of comfort and unbridled gaming precision. Enjoy extended gaming sessions in comfort with its right-handed ergonomic form factor crafted for the world of competitive gaming; and when the difference between victory and defeat is determined between heartbeats, the 3500dpi Razer Precision 3.5G infrared sensor translates your every movement into frags with pinpoint accuracy.
- 3500dpi Razer Precision™ 3.5G infrared sensor
- Ergonomic right-handed design
- 1000Hz Ultrapolling™ / 1ms response
- Five independently programmable Hyperesponse™ buttons
- On-The-Fly Sensitivity™ adjustment
- Always-On™ mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60–120 inches per second and 15g of acceleration
- Zero-acoustic Ultraslick™ Teflon feet
- Gold-plated USB connector
- Seven-Foot, lightweight, braided fiber cable
- Approximate size: 128mm (length) x 70mm (width) x 42.5mm (height)
Was £54.98 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Razer Naga 5600DPI MMO Laser Gaming Mouse @ £60.98 inc VAT
The Razer Naga is the ultimate Massively Multiplayer Online Gaming mouse that shifts the balance between keyboard and mouse by putting an unprecedented number of in-game commands in one place. A multi-button thumb grid and Razer’s MMO game interface add-on combine to place every command you need in the palm of your hand. An ergonomic form shaped to maximize ease of use lets you game in comfort for hours on end. With the Razer Naga, you will Get Imba.
- 5600dpi Razer Precision 3.5G Laser Sensor
- 1000Hz Ultrapolling™ / 1ms response time
- 200 inches per second max tracking speed
- 17 MMO-optimized buttons (including 12 button thumb grid)
- Optional MMO-specific software AddOns
- Unlimited character profiles with AddOns
- Approximate size: 116L x 69W x 41.6H (in mm)
Was £70.99 Inc. VAT
Only £60.98 inc VAT.
ORDER NOW
Saitek Cyborg V7 Illuminated Gaming Keyboard @ £49.98 inc VAT
Witness the true power of Cyborg and take your gaming to the next level with the Cyborg Keyboard range. When performance is key, customization is vital, and losing is not an option, only Cyborg brings the power you crave.
- Touch-sensitive, backlit dashboard Control Panel – Configure your lighting, media and volume controls with the brush of a finger.
- Cyborg Mode – Instantly disable the Windows® keys and change the color and brightness of your gaming keys at the touch of a button.
- 12 programmable ‘Cyborg’ keys – Store your favorite macros for buying equipment, activating abilities or just for initiating your favorite trash talk.
- Powerful ST Programming Software – Create profiles for each game that you play in order to save different button configurations.
- Hard wearing, metal-plated key caps in key gaming areas are designed to withstand the punishment that pro gamers demand.
Was £54.98 Inc. VAT
Only £49.98 inc VAT.
ORDER NOW
Qpad MK-85 LED Pro Backlit Mechanical Gaming Keyboard - UK Layout @ £119.99 inc VAT
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.
For gamers, it’s all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it’s the perfect gaming keyboard. Nuff said...
- Key switch: Cherry MX mechanical switch technology
- Cherry Red Switches
- N Key Roll over: Full N-Key roll over via USB
- Key strokes: 50 Million
- Lighting: Individual LED backlight on every key for enhanced visuals
- Lighting features: Four levels of brigthness allow you to locate keys easily
- Connectors: Gold plated USB connectors for extremly low latency
- Media keys: Media keys for volume control, play, pause and skip tracks
- USB Hub: Two high speed USB 2.0 ports
- Audio ports: 3.5mm headphone-out and microphone-in jacks
- Cable: 1.8 meter braided cable
- Extras: 4 extra orange key caps and key cap puller
- Dimensions: Keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)
- Wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)
- Weight: 1.27 Kg (2.8 LBS)
- Warranty: 2 year
- Software: Customizable profiles, programmable keys and macro recording
- Supports: Windows XP, Vista, 7
Was £129.98 Inc. VAT
ORDER NOW
Microsoft Xbox 360 Controller - PC / Xbox 360 (52A-00005) @ £18.98 inc VAT
The Xbox 360 Controller for Windows works with all Windows based PCs and Xbox 360, delivering a consistent and universal gaming experience. Get a better feel for the game with vibration feedback ensuring riveting game play every time. Part of the new Game Precision Series, the Xbox 360 Controller offers precision, comfort and control that will set the standard for next-generation game controllers. The pad has precise thumb sticks, two pressure-point triggers, and 8-way directional pad for enhanced PC gaming.
- For PC and Xbox 360
- Vibration Feedback
- Ergonomic Design
- Xbox Live Play - Integrated headset jack for PC headsets and Xbox Live play
Was £21.98 Inc. VAT
ORDER NOW
Thrustmaster Hotas Warthog Joystick @ £259.98 inc VAT
The Hotas Warthog is an U.S. Air Force A-10C attack aircraft HOTAS (Hands On Throttle And Stick) replica joystick high end system. Pre-order now to be the first to receive the most anticipated military control system ever devised.
Flight Stick
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
- USB connection with upgradeable firmware
- Super-stable, weighted base (over 3kg)
- New detachable handle, crafted entirely of metal: also compatible with HOTAS COUGAR™ handle (and vice-versa)
- New replica shape
- Detachable metal plate for desk- or cockpit-style use
- New, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat: . 1 x 8-way "point of view" hat . 2 x 8-way hats . 1 x 4-way hat with push button . 1 x metal dual trigger . 2 x push buttons . 2 x pinkie push buttons
Dual Replica THROTTLES
- Innovative new H.E.A.R.T HallEffect AccuRate Technology(*):
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles
- Metal hand rest
- Locking system
- Adjustable friction system: firm, linear and fluid tension, with no dead zones
- Realistic IDLE detent with "Pull & Push"(*) system
- Realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- Realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat: . 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect) . 1 x 8-way hat . 1 x 4-way hat with push button . 1 x push button . 1 x 3-position switch (2 momentary + 1 permanent) . 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
- Weighted base (over 3kg) incorporated underneath the throttles
- Backlit functions
- 5 programmable LEDs
- 15 action buttons in total + 1 TRIM wheel: . 1 x TRIM wheel . 2 x push buttons . 5 x 2-position switches (2 permanent) . 2 x 3-position switches (1 momentary + 2 permanent) . 2 x 3-position switches (3 permanent)
Was £279.98 Inc. VAT
Only £259.98 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £349.98 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was £369.98 Inc. VAT
Only £349.98 inc VAT.
ORDER NOW
Thrustmaster TH8 RS Gearbox Shifter @ £94.98 inc VAT
To meet the expectations of numerous motor racing fans, Thrustmaster is launching the TH8 RS, a high-end, separate and versatile gearbox. The device's two configurations, H-pattern and sequential, enable drivers to select their favorite driving style.
Realism and versatility:
Some virtual drivers cannot imagine shifting speeds otherwise than with a specific gearbox. With the TH8 RS, which boasts unrivalled technical innovations supported by pending patent applications, Thrustmaster now offers a device that is realistic enough to satisfy even the most demanding drivers.
At first glance, the TH8 RS looks realistic enough to be fitted to a real car. It features a 13 cm (5.12 in.) tall stick with a removable knob; the stick is compatible with real-life universal gear shift knobs. The TH8 RS includes two interchangeable shift plates, each suited to a specific configuration H-pattern (7 gears plus 1 reverse gear) and Sequential (pull the lever towards the + mark to gear up, and push it towards the mark to gear down).
Total adjustability:
To allow users to freely adjust the TH8 RS to their convenience, the position and the rotation angles of the shift plate and clamping system can be adjusted by 360 degrees. The removable clamping system, optimized for any type of support, is also open to customization: it is suited to both table tops and shelves (1 to 55 mm thick) and cockpits alike (built-in 'screw threads' are located under the TH8 RS). Gear strokes can also be adjusted (via a downloadable PC application and the device's internal memory), as well as the gear shift's resistance.
Cutting-edge materials and technologies:
The internal mechanism, the lever, the outer housing and the clamping system are 100% metal. This robust design significantly contributes to the extremely realistic in-game sensations delivered by the TH8 RS.
Thrustmaster has also taken care to grace the TH8 RS with unrivalled precision, by including H.E.A.R.T (Hall Effect AccuRate Technology) technology featuring magnetic sensor, without any potentiometer or tact switch and therefore, without contacts, for an unlimited product lifespan. In addition, the firmware can be upgraded to offer all foreseeable evolutions, assuring users that the TH8 RS is here to make a lasting impression.
The TH8 RS with USB connectivity is compatible with the T500 RS racing wheel on PlayStation®3 (a list of compatible games is available on the Thrustmaster support website) and with all currently available racing wheels for PC.
- Extreme realism:
- Shifting gears feels just like in a real car
- 13 cm tall gear stick with knob
- Detachable knob compatible with real universal knobs
- Ultimate versatility:
- Unique design enables 2 driving styles by using the two interchangeable shift plates provided:
- "H"-pattern (7+1)
- "Sequential (+/-)"
- Used with a PC, the gearbox is compatible with all racing wheels and games on the market that support multi-USB and gearboxes
- Used with the PS3, the gearbox is compatible with racing wheels (including the T500 RS) and games (**) that have been developed to be compatible.
- 100% metal internal mechanism, lever, and clamping system
- Absolute precision:
- H.E.A.R.T HallEffect AccuRate Technology
- Contactless magnetic sensor ensures consistency over time
- No "Tact switch" no potentiometer for unlimited product lifetime
- Full adjustability:
- Upgradable firmware and internal memory with adjustable gear-shift travel (downloadable software on PC)
- Adjustable resistance when changing gear
- Shift-plate position and rotation adjustable by 360°
- Clamping system position and rotation adjustable by 360°
- Optimal clamping (built-in screw threads + removable clamping system):
- Tables or shelves from 1-50 mm in thickness
- Cockpits
Was £109.99 Inc. VAT
Only £94.98 inc VAT.
ORDER NOW
"Titan 8000a Krypt" AMD Bulldozer 3.60GHz Quad Core System @ £474.95 inc VAT
The "Titan 8000a Krypt" features a AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- Choose from a selection of graphics cards to meet your performance needs
- 8GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Antec 300 Gaming Case (default choice, options available)
- Power Supply: OCZ ZS 650w PSU
- CPU: AMD Bulldozer FX-4 Quad Core 4100 3.60GHz Processor
- Motherboard: AMD 760G Chipset (AM3+) Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: 1TB HDD
- Graphics Card: AMD 760G Onboard (default choice, options available)
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
- Cooling: x2 White LED 120mm Fans
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 performance at an excellent price point.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £524.95 Inc. VAT
Only £474.95 inc VAT.
ORDER NOW
"Ultima 9400i Tyrannosaur" Intel 4.80GHz Quad Core System @ £1,685.95 inc VAT
The "Ultima 9400i Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima 9400i Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2700K CPU overclocked to a massive 4.80GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima 9400i Tyrannosaur".
Why You Should Buy This System
- A guaranteed 4.80GHz performance for the price of 3.50GHz
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: NZXT Phantom Enthusiast Full Tower Case - Orange/Black (default choice, options available)
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2700K 3.50GHz Sandybridge overclocked to 4.80GHz
- Motherboard: Asus Maximus IV Extreme -Z Intel Z68 (Socket 1155) DDR3 Motherboard
- Cooler: OcUK H²Flo Extreme Liquid Dual Fan CPU Cooler w/ x2 Sharkoon Silent Eagle Fans
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card (SLI option available)
- Sound: Onboard 7.1 Audio
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima 9400i Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel Z68 Chipset. Hunt down your prey with the "Ultima 9400i Tyrannosaur" and be the ultimate predator.
Was £1,785.95 Inc. VAT
Only £1,685.95 inc VAT.
ORDER NOW
Battlefield War Commander Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Limited Edition Quad Core System @ £739.96 inc VAT
Ready the Scud missiles, arm the Tomahawks and prime the Nukes. Fire up the tanks, scramble the jets and roll in the artillery! Control the Battlefield in the palm of your hand with the "Battlefield War Commander", designed and engineered for hardcore gaming. During the heat of the battle the "Battlefield War Commander" will complete the mission no questions asked. With a choice of DX11 graphics cards to choose from, you can equip yourself with the right weapon for the mission ahead.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel Z68 Chipset GEN3(Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: OcUK H2 Flo CPU Cooler
- Hard Drive: 500GB HDD
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Command, control and dominate the battlefield with the "Battlefield War Commander" system.
Was £789.96 Inc. VAT
Only £739.96 inc VAT.
ORDER NOW
"Primo 6100i" Intel Core i3 2100 3.10GHz DDR3 Dual Core System @ £369.96 inc VAT
The "Primo 6100i" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 2100 3.10GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK IMP microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 2100 3.20GHz (Clarkdale)
- Motherboard: Intel H61 (Socket 1155) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB or 8GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Was £401.96 Inc. VAT
Only £369.96 inc VAT.
ORDER NOW
Krypton Z68 TURBO Intel Core i5/i7 @ 4.60GHz DDR3 Overclocked Bundle @ £393.96 inc VAT
Designed by experts the "Krypton Z68 TURBO Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.60GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB (8GB option available) of Dual Channel DDR3 memory delivers unlimited bandwidth
- Z68 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 & SATA 6GB/s compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i5 2500K or i7 2700K overclocked @ 4.60GHz
- Motherboard: Gigabyte Z68X-UD5 (Socket 1155) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £403.97 Inc. VAT
Only £393.96 inc VAT.
ORDER NOW
OcUK Tech Lab - "Ultima 9575i TUNDRA" Intel i7 4.80GHz Quad Core System @ £1,479.95 inc VAT
Winter is a time for many things; gifts, family, celebration and GAMING! Stay warm inside and pwn your friends whilst all the noobs play around in the snow! The latest games releases are what Winter is about for most gamers. We have a special edition range of systems designed just for that sole reason. Providing excellent performance at any price point to keep you entertained through out this Christmas and beyond! DX11, SATA 6GB/s, USB 3.0 aren't just cool acroynms, they are all standard features of our extreme gaming systems. Whether it is taking to the skys in a fighter jet, racing down Laguna Seca raceway or storming through the streets of Russia, our extreme range of gaming systems will see you through!
- True DX11 gaming performance available from a choice of compatible graphics cards
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Corsair 600T - White
- Power Supply: PC Power & Cooling Silencer MK III 600w PSU - White
- CPU: Intel Core i7 2700K 3.60GHz @ 4.80GHz Sandybridge
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Custom Watercooling Loop
- Hard Drive: 2TB HDD
- Graphics Card: Choice of the latest DX11 Graphics cards
Service Package
Ultimate performance for the ultimate gamer. Custom watercooling keeps you cool in the heat of the moment and dyanamic white & black styling makes you stand out in the crowd.
Was £1,579.97 Inc. VAT
Only £1,479.95 inc VAT.
ORDER NOW
Workstation PRO P67 Intel Core i7 2700K 3.50GHz Bundle - 16GB @ £669.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Intel Core i7 2700K processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
* Windows 7 Professional 64 BIt is recommended as minimum to fully utilise this bundle's potential
- A solid, optimised 3.50GHz core speed with 4 core performance provides outstanding processing power
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
- CPU: Intel Core i7 2700K 3.40GHz @ 4.50GHz Sandybridge CPU
- Motherboard: Asus P8P67 WS Intel Z68 (Socket 1155) DDR3 Motherboard
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Cooler Master Hyper 212 EVO CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £699.98 Inc. VAT
Only £669.98 inc VAT.
ORDER NOW
BitFenix Shinobi USB3.0 Gaming Case - White/Blue @ £45.98 inc VAT
Named after some of the most feared assassins of the modern age, Shinobi empowers the digital warrior to silently and efficiently dispatch his opponents. Maximum expansion and compatibility with long graphics cards enables you to equip Shinobi with the tools you need to get the job done. Superior cooling options allow the system to stay cool and collected during the heat of battle, while a sophisticated yet understated styling shows the opposition you mean business.
Killer Looks
Shinobi carries through the signature BitFenix design philosophy of clean lines, understated elegance, and modern styling. If looks could kill, a glance at Shinobi could be your last.
Choose your destiny
The stealthy digital warrior must adapt to their environment. Available in with or without a windowed side panel, you can choose the Shinobi that blends perfectly with your surroundings. Whether you choose to walk the path of light or darkness, Shinobi has you covered.
Maximum Expansion
Serious rigs require serious hardware. That's why Shinobi is engineered to handle up to three 5.25" drives or eight 3.5" hard disks. You can also install a 2.5" SSD with the included adapter. Best of all, Shinobi can easily accommodate long graphics cards, which means that you can outfit it with the hardware necessary to eliminate the opposition.
Efficient Cooling
The effective gaming rig, like the warrior who wields it, must be cool under fire. Shinobi is adorned with unique mesh areas that can quickly dissipate excess heat. Shinobi can accommodate a bevy of fans - up to seven 120mm or two140mm fans can be installed to ensure that all hardware stays as cool as the blood running through an assassin's veins.
Plenty of connectivity
The efficient warrior must have easy access to all the tools they need to get the job done. Equipped with no less than four USB 2.0 ports, Shinobi offers plenty of connectivity for all your USB devices so that you can keep you gear connected and ready for battle.
DIY Friendly
Fighting should be done in game -- not with your hardware. Shinobi comes with a wealth of DIY-friendly features, ensuring that getting your system setup is quick and efficient. A CPU cooler cutout makes it easy to change out your CPU cooler should the need arise. Shinobi comes with filtered fan intakes, keeping the interior clean and your system looking great. Shinobi Window even comes with convenient tool-free drive locking mechanisms for ultimate convenience.
BitFenix Quality
Shinobi comes with all the amenities and design touches characteristic of BitFenix chassis. BitFenix SofTouch™ Surface Treatment for resistance to fingerprints and stains surrounds the brushed gunmetal BitFenix logo emblazoned on the front. A luxuriously black coated chassis exudes both quality and refinement. With Shinobi, users can experience BitFenix quality both inside and out.
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 2 x USB2.0 / 2 x USB3.0 & 1 x Audio
Was £49.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £112.98 inc VAT
nonl2br <center><iframe width="560" height="315" src="http://www.youtube.com/embed/Q1bC-XVnI-k" frameborder="0" allowfullscreen></iframe></center>
<br>
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough. <br>
<br>
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)<br>
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX<br>
- 5.25” Drive Bays: x 5<br>
- 3.5” Drive Bays: x 7<br>
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)<br>
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)<br>
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)<br>
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)<br>
- Cooling Bottom: 2 x 120mm (optional)<br>
- PCI Slots: 9.<br>
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio<br>
- Power Supply: PS2 ATX (bottom, multi direction)<br>
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking<br>
- Maximum CPU Cooler Height: 193mm<br>
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)<br>
- Maximum MB Tray Clearance (rear): 34.5mm<br>
<br><br>
<a href="http://www.techpowerup.com/reviews/Bitfenix/Shinobi_XL/" target="_blank"><img src="http://www.overclockers.co.uk/LP/productimages/reviewlogo/tech_powerup_recommeded.jpg"></a>
Was £119.99 Inc. VAT
Only £112.98 inc VAT.
ORDER NOW
BitFenix Merc Beta Gaming Case - Black @ £29.99 inc VAT
Getting a quality gaming chassis doesn’t necessarily mean spending a small fortune. Introducing BitFenix Merc - an unprecedented value in gaming cases. Merc comes in two flavors: Merc Alpha and Merc Beta, which gives you the option of going with additional fan locations, or choosing a more streamlined look. Ample expansion possibilities mean your Merc can grow with the rest of your system, while friendly DIY features make system installation headache-free. Armed with multiple fan locations and rich connectivity, Merc lets you get your game on without breaking the bank.
Select Your Warrior
Different battles call for different troops. Select Merc Alpha for extra top panel cooling or Merc Beta for a more streamlined look. With BitFenix Merc, the choice is yours.
Ample Expansion
Small but rugged, Merc provides ample expansion possibilities, including three 5.25", seven 3.5", and one 2.5” drive bay. Seven PCI slots accommodate a wealth of expansion cards, and best of all, Merc even handles SSD drives and the longest graphics cards, enabling you to equip the latest firepower to bring the fight to your adversaries.
Rich Connectivity
Each battle is unpredictable, so you need to be fully equipped at all times. With four included high speed USB 2.0 ports, Merc allows you to connect all of your gaming peripherals without the need to purchase separate USB hubs.
Impressive Value
With its black coated interior and quality black cabling, you'll be surprised as to how little Merc costs to bring into your camp. Big features for small money - that's BitFenix Merc.
- Dimensions: 439 x 190 x 490mm
- Motherboard Support: Mini-ITX, MicroATX, ATX
- 3.5" Drive Bays x 7
- 2.5" Drive Bays x 1
- Front Cooling: 2 x 120mm Fan (optional)
- Side Panel: 2 x 120mm (optional)
- I/O Ports: 4 x USB2.0 / 2 x Audio
Was £31.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
13 Jul 2010
Nice prices... nice to know that the 2tb wd are still pricey... i just upgraded my 2x 2xtb wd for 2 x 3tb seagate. gonna sell them to my mate for half the price...
bluray and dvd price are resonable as well.. just wished you'd sell the blu-ray in 10 pack cake boxes. :)
12 Aug 2003
Dogsbodyville
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card @ £323.99 inc VAT
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
Was £339.95 Inc. VAT
Only £323.99 inc VAT.
ORDER NOW
According to the Asus web-site, the card dimensions are:
http://www.asus.com/Graphics_Cards/NVIDIA_Series/ENGTX580_DCII2DIS1536MD5/#specifications
Dimensions 11.5 " x 5 " Inch
Which is it? Is 10.24" the length of the PCB (ie not including the connector 'L'). This is a deal-breaker. 11.5" wont fit in my CoolerMaster case: http://www.coolermaster.co.uk/product.php?product_id=6644
11 Jul 2011
Abertillery - S.Wales
You couldnt possibly do a couple of special offers on say 140mm spectre pros and a HD6970 waterblock that matches the XSPC raystorm?
5UB didnt get me a mug @ GSL, so I must be entitled to some form of compensation :p
14 Jan 2010
Mid-Wales
The Asus GeForce GTX 580 DirectCU II has a monster cooler :o Also the mouse with the keypad on the side what the... :D Some interesting stuff there I fancy the thrustmaster gear stick :)
16 Mar 2012
Hove
Tbh i've been disappointed with my first forage into Razer mice... with the Lachesis, im sure the naga is brilliant but i wouldn't use all of the side buttons to their potential.
Might have to grab myself a survivor USB drive though :D
